Old 08-17-2016, 08:59 PM   #1
Originally Posted by 2000986s View Post
CoBeerToad: I noticed that in this thread you mentioned you're from the Chicagoland area. Has the insane humidity during a couple weeks this summer made your boxster act weird at all? I have noticed on a really humid day the car doesn't always start up right away, like it sounds like it's going to misfire but then at the last second it comes to life. Also, when in neutral or sitting in first gear with the clutch depressed, the car likes to actually rev itself without me giving any throttle. It'll fluctuate from about 500rpms to 1000 rpms, occasionally jumping all the way to 1200. This is when I'm just standing still at a stop light. It's so pronounced that a 350z actually thought I was trying to antagonize a race one time... Lol. I do know that I need a new o2 sensor but not sure if that even would cause something like this. Any thoughts or is it just a 16 year old car acting weird in the humidity?
Most likely suspects; MAF failing, throttle body dirty, or intake/vacuum leak.
Nothing to do with humidity.
Old 08-31-2016, 05:20 AM   #2
CoBeerToad's Avatar
No issues with revving. My idle is pretty steady in neutral and when the clutch is depressed.
I haven't had any issues with cold starts on hot days, but when I run it to the store and come back out, the restart is like you described. I haven't given it much thought as it always seems to catch "at the last second" and has never failed me. Knock on wood.
I'm not really smart enough to know what causes these issues. It's probably along the lines of what thstone said. I think I saw in a thread here a way to clean the MAF, but you'd have to search for the thread. Seems like that might be the first thing I'd look at as it might be the easiest and is more than likely the culprit from what I've heard.
CoBeerToad is offline   Reply With Quote
Old 05-16-2019, 08:55 AM   #3
I porsched today!
Hey all...
I live in FL where this time of year is in the upper 90's. I own a 2.7 2001.
I too have been experiencing the high pitch whine, both at start up first thing and if I'm out and the car has sat for most of the day. I keep reading the posts, but it seems there's not quite a definitive answer that I'm seeing. So, is this normal?
"When you have a dream, don't let anything dim it. Keep going, keep trying, the sky is the limit."
1M_FA5T is offline   Reply With Quote
Old 05-17-2019, 02:41 AM   #4
flouese's Avatar
Originally Posted by 1M_FA5T View Post
Hey all...
Where in Florida? I'm 20 miles of Jacksonville, almost to the FL/GA border on the 95.
99 Boxster base
1966 912 3 gauge
flouese is offline   Reply With Quote
