Old 07-23-2012, 02:40 PM   #1
exhaust tip
I wonder if someone could give me an idea how to replace my exhaust tip on a 2000 base Boxster.I received an exhaust tip that is suppose to fit my Boxster and replace the oval one with a double one.I think the 2000 model exhaust tip is soldered.But I am wondering if once removed, the outlet from the exhaust is oval as well.The double exhaust tip has an 2 1/4 single attachment(round) to the exhaust system.Is there any way that I can install this.My car is in storage right now and I don't have access to visually look at it.Thanks
lahalte is offline   Reply With Quote
Old 07-23-2012, 08:27 PM   #2
I believe that replaceable exhaust tip is from my-03. I have 01 box and the chrome tip is part of the muffler.
sb01box is offline   Reply With Quote
Old 07-23-2012, 08:33 PM   #3
BYprodriver's Avatar
Post a picture of the one you have & someone will know if it is oem
Old 07-24-2012, 04:34 AM   #4
exhaust tip
Thanks.I should have a picture by the end of the day.
Old 07-24-2012, 05:24 AM   #5
exhaust tip
Here are a few pictures of the exhaust tip that I would like to install on my 2000 base Boxster.Any ideas?
Old 07-24-2012, 10:11 AM   #6
Opposed to Subie Burble
Overdrive's Avatar
I pulled this from the "Crios mod" thread:
You can see the section of the muffler that the tip surrounds is oval in shape, so this round tip you have does not seem like it will work. It is a single hole, split down its center, but it's not round. I'm nor sure where you got it from, but that looks like something universal.
On the older cars what Porsche had for a tip modification was a chrome surround that would clamp over the original tip and stick out slightly from the rear.
-O/D
IMSR + RMS
Robbins glass window top
Old 07-24-2012, 02:20 PM   #7
exhaust tip
Thanks for the picture.When I ordered this particular exhaust tip it was specified for a base 2000 boxster.It would be easier to change the exhaust system in its entirety to get the look I was hoping.I will check with the distributor to clarify the order.Thanks
Old 07-24-2012, 02:54 PM   #8
Overdrive's Avatar
I imagine it may be possible for a muffler shop to tweak that tip and weld it onto your muffler in the same way that your stock tip is welded on. As long as they could make sure it sealed up and was level and their job doesn't look like a Frankenstein monstoer, that still an option to consider. It wouldn't cost much for them to do something that simple if they can, but I imagine you were looking to be able to just clamp on the new tip and go.
-O/D
IMSR + RMS
