Old 07-05-2012, 10:40 AM   #1
jdiba's Avatar
Don't forget to check/change your cabin air filter or you could end up with this...
Mouse condominium.
My 3 4 legged mouse hunters will be roaming the garage at random this fall and
winter on patrol. I used traps last winter and got alot of them but the damage had
been done.
-May all the roads you travel in life be Speed Trap free.
01 986 Boxster S. Arctic Silver. 6 speed manual. IMSR/RMS.
jdiba is offline   Reply With Quote
Old 07-05-2012, 11:03 AM   #2
boxster6354's Avatar
DAMN!!!
Never seen that before.
boxster6354 is offline   Reply With Quote
Old 07-05-2012, 01:30 PM   #3
Mine looked similar last year. There was also a nest on top of the engine.
Old 07-05-2012, 01:51 PM   #4
Current Cars
Ok. So to make sure that does not happen to me. Where is the cabin air filter ?
Neekk1 is offline   Reply With Quote
Old 07-05-2012, 02:19 PM   #5
jdiba's Avatar
On the 986 open your frunk (front trunk) and stand at the front of the vehicle. Its up in the left hand
far corner right below the winshield (passenger side), right against the firewall. Black plastic cover.
Thats the cover of the HVAC. They make one with charcoal in it that absorbs odor.
Here's a link on how to do it too.
How to Replace a Boxster Cabin Air Filter | eHow.com
Old 07-05-2012, 05:55 PM   #6
Yes, I had the same problem a couple of years ago (Boxster, Lexus, and Avalon) - two separate garages. I now liberally throw month balls on my garage floor and corners and use one of those mouse repellers you plug into the wall. So far so good (though I still check my filters monthly during the winter months.
Soetekouw is offline   Reply With Quote
Old 07-05-2012, 07:55 PM   #7
Joel-Box-ster's Avatar
Damn! Is that fiber glass insulation? mine is so dirty you cant see sunlight thru it.
2K Boxster White/Grey Int./Hardtop/TIP
Joel-Box-ster is offline   Reply With Quote
Old 07-06-2012, 06:19 AM   #8
jakesbox
trimer's Avatar
that is so gross that I just went out on to the internet and found a replacement filter (WIX) at O'Reillys and will be picking it up tomorrow and installing. I have no clue what mine looks like, but not taking any chances!
Old 07-06-2012, 08:51 AM   #9
Yeah, mice will get into everything. I change my cabin air filter at least once a year and use the charcoal version to cut down on the diesel fume smell on the highway.
Old 07-06-2012, 09:17 AM   #10
jdiba's Avatar
The moth balls help alot. I did alot of different stuff after the fact...cats, moth balls, traps. It
was all out war. And I got off EASY. All I had to endure was the foul smell when I'd put the vent
on. Do you realize how expensive this could get if they decided to just start chewing on wiring
!?!!!? I consider myself likely. Will never happen again. Was my own little version
of the movie 'Mouse Hunt'.
To say I was in shock when I pulled the thing out is an understatement. Was like a horror
movie. Yes, that is insulation btw.
Cats will be patrolling the garage this fall and winter. I knew I kept them
mangy critters around for SOME good use
Old 07-06-2012, 09:21 AM   #11
Originally Posted by jdiba View Post
Or you could look at it this way... look at all the crap that your filter kept out of your car!
RobbieKnobbie is offline   Reply With Quote
Old 07-06-2012, 09:22 AM   #12
Sadly I have a detached garage, so the cats can't patrol there. Maybe I need to build a Cat-walk between the buildings. ( rimshot )
Old 07-06-2012, 09:26 AM   #13
jdiba's Avatar
My Indy told me all you have to do is put the cats in there for a couple days for a few hours now and then. Once the mice get their scent, they immediately start looking for a new place to live. The gig is up.
Just a word of advice, though I'm certain it doesn't need mentioning. If your cats are like mine, you'll wanna cover your car. Or you end up with this:
http://www.youtube.com/watch?v=dqGIUGF3PzY
Old 07-06-2012, 03:54 PM   #14
jakesbox
trimer's Avatar
Good thing i saw this thread! Went out to check on mine after ordering one. It was actually not terrible but not great...but someone had written on it 3/2009 so assuming last time it was changed! Hell i didnt even know the car had one! Thanks!!
Old 07-06-2012, 09:15 PM   #15
Received and changed mine today..
Old 07-07-2012, 03:27 AM   #16
cabin filter
There were the same signs of mice in our Boxster too. We also had a small nest under the arm rest bin where the parking brake is adjusted.
rem503 is offline   Reply With Quote
Old 07-12-2012, 10:59 PM   #17
Originally Posted by trimer View Post
that is so gross that I just went out on to the internet and found a replacement best cabin filter (WIX) at O'Reillys and will be picking it up tomorrow and installing. I have no clue what mine looks like, but not taking any chances!
Well good luck to that Hoping you would have a cleaner cabin filter. Happened to mine as well, but not as dirty/grose like that.
kotto is offline   Reply With Quote
Old 07-13-2012, 02:45 AM   #18
I find the polland filter very useful when the top is down most times, the german do have a sense of humor?
howe is offline   Reply With Quote
Old 07-13-2012, 04:25 AM   #19
Bobiam's Avatar
Once a mouse has been there, they (or their friends and relatives) will be back. I got 1/4" welded wire cut to the filter shape and inserted it on top of the filter which was almost eaten through twice. Unless the rodents have little cutting torches, I should be OK.
2001 Boxster, GT3 console delete, lower stress bar, RoW M030 suspension package, painted bumperettes.
Bobiam is offline   Reply With Quote
Old 07-13-2012, 06:32 AM   #20
I had the same thing happen. Since then, I now try to "mouse-proof" the car and garage. It seemed to work last year. I use peppermint oil in the car at places mice might frequent (supposedly mice hate peppermint oil and it doesn't smell bad). I put down several glue traps and my exterminator sprays bobcat urine in appropriae places. When he was spraying the first time, we saw several mice "getting the hell out of Dodge".
Lawdevil is offline   Reply With Quote
