06-02-2012, 06:30 PM
#1
Remote Key - Microswitch came off....
The remote button to unlock the doors stopped working. When I opened the key head, the tiny Microswitch was loose. When placed back in its home, it worked, which is good.
The question is how do I get that switch resoldered in place without making a new problem. It looks like you need a fine tipped iron and a very steady hand....?
Anyone done this ?
06-02-2012, 09:29 PM
#2
06-02-2012, 10:26 PM
#3
A fine tip soldering iron and a steady hand.
You can carefully file down a regular 30watt soldering iron tip, which works well. I use a Dremel with a cutting wheel to grind it down for fine work. Don't forget to use rosin(not rosin core solder, that stuff is crap and makes a mess). That will make the solder flow nicely and really does the "fine" work for you.
06-03-2012, 12:37 PM
#4
Thanks for the tips: Filed an old low wattage iron to a fine point and carefully resoldered the switch bac in place. Heps to have someone hold the switch down so the switch doesn't,t move.
Remote works again..
06-03-2012, 12:55 PM
#5
Any pics? I think I may have the same problem.
2006 Hummer H3 - RED 76k mi - LIFTED - 3rd row custom seating on 35's and a manual tranny.
1997 Boxster Guards - RED 86k mi - 19" Lobster Claw Wheels on Conti's , Porsche side decal for extra "speed", manual tranny -signed by Hurley Haywood
Phoenix, Arizona
06-03-2012, 01:57 PM
#6
Glad you got it solved!
06-03-2012, 03:10 PM
#7
This is one I missed, should'a taken pics. Perhaps this will illustrate: I opened the FOB and found one of the tactile microswitches loose inside. If you open a FOB, there should be two very small switcheds located immediately below where you press.
To determine if there was further damage, I placed the switch between the two solder points and tested it by pushing down on the switch. The remote still worked so I carefully--take your time-- soldered the switch back in. The trick is to NOT overheat. Get a small amount of solder on the point of the iron, touch it to the connection and get out....Once one end was secured, the other end was easy.
05-09-2013, 08:00 AM
#8
Thanks for the tip!!
Just fixed two remote keys--a little solder & a little patience and saved close to $500.
Thanks for the encouraging advice!!!!
05-09-2013, 08:02 AM
#9
Fixing keys
BTW-
Used a piece of double stick tape on the bench to hold the chip/battery holder and had two hands free for soldering....
