Old 06-02-2012, 10:26 PM   #3
particlewave
A fine tip soldering iron and a steady hand.
You can carefully file down a regular 30watt soldering iron tip, which works well. I use a Dremel with a cutting wheel to grind it down for fine work. Don't forget to use rosin(not rosin core solder, that stuff is crap and makes a mess). That will make the solder flow nicely and really does the "fine" work for you.
