Old 06-12-2012, 12:11 PM   #21
jcb986's Avatar
TITAN SINTOPOID 75W-90 synthetic axle fluid from Pelican Parts
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
Old 10-17-2012, 01:39 PM   #22
Titan Sintopoid is not the oil for cold climate areas. Until the tranny warms up it is so hard to shift. Crunches and get you wondering if something is wrong with the tranny. Did not have that with the old oil that was in the car. Switching to Porsche fluid.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
Old 10-17-2012, 08:49 PM   #23
I had my local shop use original Porsche oil when the shift arm was backing out of the transaxle and I had a small leak (and poor shifting). Oil re-fill was about $200 + $100 labor.
Old 10-18-2012, 02:33 AM   #24
28 bucks a liter times 3 and DIY. Add few bucks for the plug seal. $90 tops.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
Old 10-18-2012, 04:46 AM   #25
Homeboy981
Homeboy981's Avatar
One more note about the Amsoil…
It is GOOD on COLD shifts! First to second is no problem, even when cold.
Feels better than whatever was in there before, most likely Porsche stuff. Very good on HOT days too! Have not missed a shift since I have run this stuff. It seems to "slide" into gear easier. At a stop the gearshift moves with little effort (NOTE: that may be more indicative of gear wear than actual lubrication however).
We'll see how it looks when I have to replace it in another 60k miles!
@JD - can you get that oil by the liter?
