Old 05-14-2012, 02:29 PM   #1
Bobiam's Avatar
Frunk/trunk release backlights staying on
The 2001 has front and rear trunk release switches by the driver's door. These are backlit so you can find 'em in the dark. The lights are LEDs so they don't take any power to speak of.
My problem is that unless the car is locked/alarmed, the backlights don't go off! If this happens overnight it won't harm the batt. But it killed my 6 yr old batt after being ON for a week or two without the car running.
I just changed the old batt and the problem remains. I can take the cover off and disconnect the LEDs I suppose, but I'd rather fix it right.
Any suggestions? One person already suggested that the ignoition switch may be the culprit. I just don't want to start changing parts all ofthe place until I get some more ideas. Sounds to me that there is a faulty timer relay somewhere.
Thanks......
2001 Boxster, GT3 console delete, lower stress bar, RoW M030 suspension package, painted bumperettes.
Bobiam is offline   Reply With Quote
Old 11-23-2014, 03:01 PM   #2
Bobiam's Avatar
Just found the answer to my own question. Only took 2 years! I guess it was not these little lights that killed my batt, but age. The Bentley manual says that these lights come ON when the car is unlocked, and go OFF when the car is locked or when the car is not used for 2 hours. I imagine that I didn't check it after 2 hours. Who would think that the lights would be needed at that time!!!???
Old 11-24-2014, 10:59 AM   #3
Multi-Boxer Driver
Deserion's Avatar
My '04 behaves this way as well. Also ditto on the little LEDs in the interior door handles and dome light assembly.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 12-22-2014, 02:57 PM   #4
BOOTLEG's Avatar
2001 BOX S w/dead bat = trunk lids inoperative. Tried the alternate bat + to red fuse, - to grd. on door hasp, but nothing. Pulled rt. side inner fender liner and found hole where cable loop should be..... nothing.
Any thoughts?
BOOTLEG is offline   Reply With Quote
Old 12-22-2014, 03:39 PM   #5
Any thoughts?
may be rerouted to tow hook in front or in mine and your case around the center opening in front that S models have. Rerouted rear to under bumperette, Good luck....probably rerouted
nicecar is offline   Reply With Quote
Old 12-22-2014, 07:21 PM   #6
Doubt the release cable was removed or severed. I was in similar situation couple months ago. Do a THOROUGH search under front end, behind bumper cover
, etc...
jotoole is offline   Reply With Quote
