Frunk/trunk release backlights staying on
The 2001 has front and rear trunk release switches by the driver's door. These are backlit so you can find 'em in the dark. The lights are LEDs so they don't take any power to speak of.
My problem is that unless the car is locked/alarmed, the backlights don't go off! If this happens overnight it won't harm the batt. But it killed my 6 yr old batt after being ON for a week or two without the car running. I just changed the old batt and the problem remains. I can take the cover off and disconnect the LEDs I suppose, but I'd rather fix it right. Any suggestions? One person already suggested that the ignoition switch may be the culprit. I just don't want to start changing parts all ofthe place until I get some more ideas. Sounds to me that there is a faulty timer relay somewhere. Thanks...... |
Just found the answer to my own question. Only took 2 years! I guess it was not these little lights that killed my batt, but age. The Bentley manual says that these lights come ON when the car is unlocked, and go OFF when the car is locked or when the car is not used for 2 hours. I imagine that I didn't check it after 2 hours. Who would think that the lights would be needed at that time!!!???
My '04 behaves this way as well. Also ditto on the little LEDs in the interior door handles and dome light assembly.
2001 BOX S w/dead bat = trunk lids inoperative. Tried the alternate bat + to red fuse, - to grd. on door hasp, but nothing. Pulled rt. side inner fender liner and found hole where cable loop should be..... nothing.
Any thoughts? |
Doubt the release cable was removed or severed. I was in similar situation couple months ago. Do a THOROUGH search under front end, behind bumper cover
, etc... |
| All times are GMT -8. The time now is 04:12 AM. |
