Old 05-12-2012, 05:35 AM   #1
John99Boxster's Avatar
Help! Steering Wheel Airbag
Last week my horn became possessed and started randomly beeping as I was driving (embarrassing) .
So, I figured out that I need to replace/repair the bushings behind the airbag cover.....simple enough.
PROBLEM: I cannot get the two bolts (30 Torx) behind the wheel to budge! My son who is much stronger than I am even tried to loosen them and no luck....
Any ideas.....tips.....tricks?
Thanks guys
1999 Boxster
Ocean Blue Metallic/Savannah Beige | Tiptronic | Custom Rear Spoiler | 17" Turbo twist | Red Brembo Calipers | GAHH Top w/Glass Window | Tinted Windows | Cruise Control | Leather Interior | Heated Seats | Color Wheel Caps | Traction Control | Debadged
John99Boxster is offline   Reply With Quote
Old 05-12-2012, 06:24 AM   #2
I hate to suggest this and I truly hope I don't offend you, but you are turning the screw counter-clockwise from the perspective of the screw head, right? Cuz that would be clockwise from the perspective of the guy sitting in the seat. Like I said, I don't mean to insult your abilities, but that would be an easy mistake to make.
The fix, once you get the wheel off, is upgrading to a three-spoke wheel. Those four-spokers are notorious for sagging on to the horn switch.
'99 black 986
Old 05-12-2012, 09:02 AM   #3
Mark...no offense taken. I did make sure I was turning it correctly.
And, I think you are right about the three-spoke wheel.
1999 Boxster
Old 05-12-2012, 12:48 PM   #4
I had a similar problem with mine. I used a torx bit with a socket wrench and an extension for leverage.
Be careful not to strip/break the bolts, as they're pretty small.
1997 Boxster
http://i40.tinypic.com/ax1qhz.jpg
Aron in Toronto is offline   Reply With Quote
