Old 04-30-2012, 08:58 AM   #1
2003 Boxster S
Mandrew1's Avatar
DRL (Daytime Running Light) Wiring
So, I'm gonna tackle the LED DRL installation on my 2003 S, and I've amassed all the stuff I believe will be needed to sorta kinda make my 986 look newer :-)
My question is this, for anyone who has done this install, or who has installed any type of light assembly from the front bumper inward, what is the best line of action for wiring?
I've looked up/over/under/around the front fascia, but it seems pretty damn airtight (as it should be, I guess).
My point of origin will be the middle vent of the right and left air intake (DRLs with brackets), then somehow getting the wiring into the front trunk, where it will meet up with a automatic on/off relay that goes directly to the battery.
Powering it will be cake - but running the wiring install is what has me baffled. Ive seen several other posts on here that don't refer to "how they did it", or the description seems somewhat cryptic.
Anyone have ideas on this, and ideally, anyone have pics? (please?!?!) I think this information could be a good baseline standard for many, many projects.
Speed costs...how fast do you want to spend?
Mandrew1 is offline   Reply With Quote
Old 04-30-2012, 12:53 PM   #2
still plays with cars...
BoxsterSteve's Avatar
For the factory look....
Follow this link:
http://986forum.com/forums/general-discussions/35094-drl-hack.html
you'll then be able to run your low beams any time the engine is running, total cost a buck or two, tops. Super easy, and it looks factory too.
Old 04-30-2012, 05:41 PM   #3
2003 Boxster S
Mandrew1's Avatar
Originally Posted by BoxsterSteve View Post
Follow this link:
I appreciate that information - inexpensive solutions are my favorite!
Old 09-05-2021, 07:29 AM   #4
DRL Wiring
Did you wire the drls? If you did, how did you get the wires into the front trunk? Removing the bumper is not an option. I am sure 17 years has corroded the fasteners and that will create many problems. I am thinking drilling a hole into the trunk and adding a grommet to keep the trunk sealed. How did you mount the lights? Thanks for any insight.
dragonflyoh is offline   Reply With Quote
