Old 04-28-2012, 10:04 AM   #1
Clutch Job at 37000 Miles? Am I Dreaming?
Hello,
I have a 2002 Porsche Boxster S, 6Speed. The clutch last week got stock to the floor, and since has been acting weird. I did some research, and people noted the problem might be Slave and Master Cylinder. Had the shop, change the Slave, and the problem still resides. He tell me, it might be my pressure plate. The car has only 37000 miles. Can this be true?
Kianfar is offline   Reply With Quote
Old 04-28-2012, 11:07 AM   #2
Clutch to the floor is usually hydraulics.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 04-28-2012, 12:37 PM   #3
The slave is changed, I have a master that I can change. What's the next thing? How about the hydronic line?
Old 04-28-2012, 05:17 PM   #4
Clutch stuck to the floor can also be throwout bearing failure. I had this happen and had to replace the clutch, bearing, and pressure plate because all of the broken bits ate into everything else. Also replaced the dual mass flywheel at the same time since it was worn too.
Old 04-28-2012, 08:19 PM   #5
If that's the case, I was thinking of ordering the 3Piece kit, which includes
1. Pressure Plate
2. Clutch
3. Throw-out Bearing
Old 04-28-2012, 10:02 PM   #6
Steve Tinker's Avatar
You are correct - you can order a Sachs clutch kit from your favourite supplier which includes all the parts you require for the changeout.
2001 MV Agusta F4.
Old 04-29-2012, 09:11 AM   #7
This is what's been done so far. I'm trying to see if there is possible anything else I can do, and try before getting the big job done.
1. Fluid Flush - Take out the bobbles, no change
2. Clutch Slave Exchange - No change
Have not done:
1. Clutch Master Cylinder
2. Pressure Plate
3. Clutch
4. Throw bearing
