Old 04-28-2012, 05:17 PM   #4
thstone
Clutch stuck to the floor can also be throwout bearing failure. I had this happen and had to replace the clutch, bearing, and pressure plate because all of the broken bits ate into everything else. Also replaced the dual mass flywheel at the same time since it was worn too.
