Old 04-26-2012, 02:48 PM   #1
John99Boxster's Avatar
Best Oil
I Know this subject has been discussed at length, with a lot of commentary and even some heated discussions. However, I am about to do my first oil change on my 99 Boxster with 68,000 miles.
I have no idea what kind of oil is currently in the car. I am looking for an oil that will:
#1 Quiet Start up Noise
#2 Have a viscosity and weight that is good year round for my climate (30 degrees low to 95 degrees hot)
I would appreciate any educated recommendations from you guys.
1999 Boxster
Ocean Blue Metallic/Savannah Beige | Tiptronic | Custom Rear Spoiler | 17" Turbo twist | Red Brembo Calipers | GAHH Top w/Glass Window | Tinted Windows | Cruise Control | Leather Interior | Heated Seats | Color Wheel Caps | Traction Control | Debadged
John99Boxster is offline   Reply With Quote
Old 04-26-2012, 02:51 PM   #2
From what I have read I would say a 0w40 or maybe 5w40
onefastman is offline   Reply With Quote
Old 04-26-2012, 03:16 PM   #3
I believe that Porsche recommends Mobil 1 Synthetic 0-40w.
Soetekouw is offline   Reply With Quote
Old 04-26-2012, 05:00 PM   #4
- 0w40 or 5w40
- Mobil 1 or Castrol Syntec/Edge
- Change every 5K miles
- Manually check the filter element for metal debris (small yellow/brown rubbery bits are leftover engine gasket seal and are generally ok)
Old 04-26-2012, 06:16 PM   #5
Johnny Danger's Avatar
I've heard good things about Redline and Motul also .
Old 04-26-2012, 07:53 PM   #6
Joel-Box-ster's Avatar
Oil
5W40 for winter and 10W40 or 20W50 for summer.
2K Boxster White/Grey Int./Hardtop/TIP
Joel-Box-ster is offline   Reply With Quote
Old 04-26-2012, 09:40 PM   #7
Idaho Red Rocket 3's Avatar
My wife drives the 2K S as her daily driver. It now has 68K miles as well. I think many of the oils folks here on the forum recommend are probably OK. With over 40 years of motorcycling I choose to spend my money on Castrol Syntec 10W-40 for year round use. I am currently considering going to 10W-50 or 15W-50 for summer. Not sure if there is a discernible benefit yet.
I truly believe Mobil 1 is no longer the oil it used to be. I believe they stopped using Base 4 and 5 stocks and now only use Base 3. What a shame.
2000 Boxster S
Old 04-27-2012, 01:05 AM   #8
Just this week changed oil on my 2000 base w/92,300 mi from Castrol Syntec to Redline 5w40. Engine is much smoother, not that it wasn't smooth before, but such improvement has me wondering. Been changing oil + filter every 5,000 mi.
+1 on oil filter autopsy. Every change.
jotoole is offline   Reply With Quote
Old 04-29-2012, 04:17 AM   #9
Used Red Line 5W40 for a few years with excellent results. Now, for the past 2 changes, I am using Porsche approved 5W50 Mobil 1. Hard to find oil, but it's out there. I like the results even better. Here is my UOA:
File Type: pdf Boxster Oil Analysis Fall 2011 Forum.pdf (69.1 KB, 1763 views)
Old 04-30-2012, 12:46 PM   #10
Those are impressive numbers.
Old 05-15-2012, 08:16 PM   #11
Fuchs Titan 5w40 is the right oil to use in Porsche
Its the factory fill in Germany and has the right additives for the rubber used in Porsche engines. It has no recycled oil and is on the Porsche recommended list. Motul 5w40 can also be used, same company.
.lovemy986 is offline   Reply With Quote
Old 05-15-2012, 08:19 PM   #12
Fuchs Titan 5w40 full synthetic
Old 05-15-2012, 08:34 PM   #13
isnt the 5w50 the racing oil with group IV?
fivepointnine is offline   Reply With Quote
Old 05-15-2012, 10:53 PM   #14
Did an oil change last Monday - Castrol Edge Sport 0w40
rene525d is offline   Reply With Quote
Old 05-16-2012, 07:59 AM   #15
SoK
Changed the oil last night for summer, mobile 1 5w40.
2001 Seal Gray 5-Speed - 2007 Yamaha R6 - 2003 Honda Civic EX - 1999 Nissan Frontier XE - 2003 Coleman Utah
SoK is offline   Reply With Quote
Old 05-16-2012, 03:40 PM   #16
I don't know. It's NOT a racing oil. But it could be a group IV. Look here:
Old 08-25-2013, 08:58 AM   #17
Redline 5W-40 or 10W-40?
Dave Granquist at Redline suggested either of these oils for my 2004 Boxster S. (Live in a really warm inland part of Southern CA.) I've relied on Redline products for a bunch of collector cars. But I'm way short on personal expertise; like a lot of you I often rely on anecdotes of others and the best information I can find. Looking at Redline's technical data, I can see that the viscosity properties of both oils are indeed nearly the same for anything likely to be encountered in this climate.
Just reviewed my original owner's manual (MY 2004) this morning. Interesting read, clearly advises 10W-40 "or heavier," even for synthetics, 10W-40 seems to be the first choice listed for most climates. But wasn't Porsche openly endorsing Mobil 1 0W-40 well before 2004 model year?
Guess we sometimes need to use our own best judgement. Fifteen years back, Mercedes here in the states discouraged use of synthetic oil at the same time they extended the service intervals. They even encouraged dealers to give owners of new cars (including me) a "courtesy" oil change at 1000 miles, tossing out the factory synthetic fill. Result (surprise!) was sludge, eventually they offered extended engine warranty to deal with it.
riverside986 is offline   Reply With Quote
