Old 03-18-2012, 09:26 AM   #1
ChrisZang's Avatar
Small metal shavings in my oil filter - OK or time to panic?
This is the very first time that I looked at my oil filter after an oil change, so I don't know if my findings are normal or reason to be concerned.
I found a bunch of tiny non-magnetic (so I guess they are aluminum) shavings in my oil filter (see attached pic)
Oil was changed after 5,000 miles (as I always do), the engine has about 40k miles
Comments, ideas?
Old 03-18-2012, 09:43 AM   #2
I would not be overly concerned at this point, there are only a few showing in the photo, and the fact that they are non ferrous in nature says that it is not critical at this time.
Would suggest the following: Add a magnetic drain plug. After about 500-750 miles, change the filter again to see if you are getting more/less/none. Based upon what the intermediate filter check shows, keep an eye on it to see what, if anything, changes or develops.
Old 03-18-2012, 09:46 AM   #3
ChrisZang's Avatar
Thank JFP,
much appreciated. I forgot to mention that I actually added the magnetic drain plug (from Pelican Parts) at my last oil change (5k miles ago) and the magnet didn't catch anything.
Will follow your advise and check the oil filter again in 500 ~ 750 miles, (guess that will be messy
Old 03-18-2012, 11:05 AM   #4
Not really, when you pull the filter housing, a bit less than 1 quart will come out in the housing. Check the filter, put in a new one and gasket, top off the oil, and you will be back in business...........
Old 03-18-2012, 11:53 AM   #5
Topless's Avatar
+1
A few shiny aluminum bits is pretty normal. More shiny bits that are attracted to a magnet are far more serious.
Old 03-18-2012, 12:12 PM   #6
You can even just reuse the old filter after you check it. I check mine every 1500 miles. I just pull it out, check it visually, obviously not cutting it apart. The, I just clean out the canister very well, put new oil in the canister and reinstall the filter.
The oil flow is from the outside of the filter to the inside, so you will see any debris that the filter catches.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 03-18-2012, 02:45 PM   #7
Moderator
Hrmm I think it's kinda extreme reusing a filter after extended amounts e.g. 7500/10000 miles, as even if you can't see any debris, the pulp fibers accumulate fine silt in them. But, you should be fine as you said you check it and reuse after 1500 miles etc. I just changed my oil yesterday and didn't see a single speck of oil in the filter.
Old 03-18-2012, 03:11 PM   #8
We're talking about checking the oil filter between oil changes, I change my oil around 3k miles and inspect the filter around 1.5k miles to check for metal and any possible problems. I certainly am not advocating changing the oil and keeping the same filter.
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
Old 03-18-2012, 03:30 PM   #9
Porsche "Purist"
Paul's Avatar
Porsche says to change the oil filter every other oil change or 2 years.
1987 924S. 2002 996TT. PST-2
Old 03-18-2012, 04:57 PM   #10
Idaho Red Rocket 3's Avatar
I thought the oil flowed from the inside out. ?????
2000 Boxster S
Old 03-19-2012, 02:44 AM   #11
It is outside to inside. And I would never reuse an oil filter, particuarly the treated paper end cap style of the OEM, they tend to leak at the end caps with only one use.........
Old 03-19-2012, 05:54 AM   #12
I just did this same job (filter & oil) yesterday. The oil was 15 months old, but only had 791 mi. on it. It looked new coming out. What a waste. I just change it once a year and it's always way below on miles to be done. I have the magnetic plug from pelican also. It had a fine small amount of metallic sludge on the end. I cut my filter ends off and unrolled it. I didn't have the metal bits like the op. It did however, have little amber/brownish bits here and there. Maybe 1/2 dozen a the most. I've read somewhere on this forum what they might be, but can't remember????
Old 03-19-2012, 06:37 AM   #13
jaykay's Avatar
Chris,
Looks normal to me; plus they are not ferrous
986 00S
Old 03-19-2012, 07:33 AM   #14
If you have the time then pull the sump plate out and look in there as well. I found a lot more bigger pieces in there that are no ferrous. Might be a good idea to at least clean them out.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
Old 03-19-2012, 02:48 PM   #15
Porsche dealers replace a lot of motors!
2001 Boxster S 3.6, 2003 E46 M3, 94 968 Cab, 80 911 Weissach Edition, BMW 1200 CLS
smshirk is offline   Reply With Quote
Old 03-19-2012, 06:40 PM   #16
Jager's Avatar
Yep, I change my oil every 3500 to 4000 miles and change the filter (OEM style) and inspect it every other oil change. Over 227,000 miles and counting.
Jäger
300K Mile Club
Old 03-19-2012, 08:23 PM   #17
The amber/brown rubbery bits are excess gasket material. Generally not a worry.
Old 03-20-2012, 07:02 AM   #18
thstone... that's a relief! I was thinking they were parts of the chain tensioners or something??? Maybe I read that somewhere? Is the metallic "sludge" on the mag. drain plug normal??
Old 03-20-2012, 07:59 AM   #19
Really, how many? We'd love to know that number. You must have the inside scoop. Cool beans.
Old 03-20-2012, 08:06 AM   #20
Crazy!
I took the 993 Turbo out this weekend. First drive since late November, since it was in winter hibernation. I did more combined miles than this on Friday, Saturday and Sunday.
