Old 03-02-2012, 05:59 PM   #1
Mister986's Avatar
Angry Boxster S Hard to shift into gears
My 2000 Boxster S is hard to shift into all gears when the car is running. I've changed the motor mount and slave cylinder and I still can't find the problem. Does anyone know what could be the problem?
Mister986 is offline   Reply With Quote
Old 03-02-2012, 06:02 PM   #2
When was the last time the transmission fluid was changed?
Old 03-02-2012, 06:34 PM   #3
Porsche "Purist"
Paul's Avatar
How's the clutch pedal working? How far is the friction point from the floor? Have you checked the fluid level in the tranny?
1987 924S. 2002 996TT. PST-2
Old 03-02-2012, 11:50 PM   #4
Steve Tinker's Avatar
Or the fluid level in the brake / clutch resevoir, as air could be in the system ????
2001 MV Agusta F4.
Old 03-03-2012, 10:38 AM   #5
DenverSteve's Avatar
Many things, as stated above, can cause the trouble. Why are you throwing money at a problem without a proper diagnosis? Take it to someone and find out if it's your fluid, synchros or......???
Denver Steve
Carrera, Cabriolet, 6-Speed, Black/Tan
DenverSteve is offline   Reply With Quote
Old 03-03-2012, 10:39 AM   #6
Wingnut2u's Avatar
Not sure but could a bent shifter fork cause this kind of a problem?
2001 Boxster S
RUF front bumper, Techart side skirts, Gemballa rear bumper, PSS9s, Cargraphic 18" racing wheels, RUF exhaust, GT3 seats
Wingnut2u is offline   Reply With Quote
Old 03-03-2012, 11:54 AM   #7
Mister986's Avatar
Thanks a lot for the info. I had the car for a year now and the trans fluid is the only thing I haven't checked.
Old 03-04-2012, 06:53 PM   #8
Perfectlap's Avatar
Try R.O.C.S. in Belleville on Washington Ave. They'll have it diagnosed quickly.
BORN: March 2000 - FINLAND
Old 03-04-2012, 07:10 PM   #9
ckkrause's Avatar
If it shifts fine with the motor off, it's probably the clutch going....
My $0.02
-CKKrause
'11 F250 TD-Tow
'00 M5- DD
'67 912-Future Vintage Racer
'98 Boxster-SpecBox Racer
ckkrause is offline   Reply With Quote
Old 03-09-2012, 11:27 AM   #10
Is it all the gears or just 1st 2nd and reverse?
2001 Boxster S 3.6, 2003 E46 M3, 94 968 Cab, 80 911 Weissach Edition, BMW 1200 CLS
smshirk is offline   Reply With Quote
Old 03-09-2012, 11:31 AM   #11
ChrisZang's Avatar
how about checking the adjustment of the two shifter cables?
That's where I would start
Old 04-04-2014, 06:47 PM   #12
Thumbs up Will not shift into reverse
Just wanted to thank you guys. My boxster wouldn't shift into reverse, and after reading the thread I was able to remedy the problem, I used the zip ties. Works fine now. Thank you.
Sid
sidroberts2 is offline   Reply With Quote
Tags
clutch , cylinder , gear , shift
