03-02-2012, 05:59 PM
Boxster S Hard to shift into gears
My 2000 Boxster S is hard to shift into all gears when the car is running. I've changed the motor mount and slave cylinder and I still can't find the problem. Does anyone know what could be the problem?
03-02-2012, 06:02 PM
When was the last time the transmission fluid was changed?
03-02-2012, 06:34 PM
Porsche "Purist"
How's the clutch pedal working? How far is the friction point from the floor? Have you checked the fluid level in the tranny?
1987 924S. 2002 996TT. PST-2
03-02-2012, 11:50 PM
Or the fluid level in the brake / clutch resevoir, as air could be in the system ????
2001 MV Agusta F4.
03-03-2012, 10:38 AM
Many things, as stated above, can cause the trouble. Why are you throwing money at a problem without a proper diagnosis? Take it to someone and find out if it's your fluid, synchros or......???
Denver Steve
03-03-2012, 10:39 AM
Not sure but could a bent shifter fork cause this kind of a problem?
2001 Boxster S
RUF front bumper, Techart side skirts, Gemballa rear bumper, PSS9s, Cargraphic 18" racing wheels, RUF exhaust, GT3 seats
03-03-2012, 11:54 AM
Thanks a lot for the info. I had the car for a year now and the trans fluid is the only thing I haven't checked.
03-04-2012, 06:53 PM
Try R.O.C.S. in Belleville on Washington Ave. They'll have it diagnosed quickly.
03-04-2012, 07:10 PM
If it shifts fine with the motor off, it's probably the clutch going....
My $0.02
-CKKrause
'11 F250 TD-Tow
'00 M5- DD
'67 912-Future Vintage Racer
'98 Boxster-SpecBox Racer
03-09-2012, 11:27 AM
Is it all the gears or just 1st 2nd and reverse?
2001 Boxster S 3.6, 2003 E46 M3, 94 968 Cab, 80 911 Weissach Edition, BMW 1200 CLS
03-09-2012, 11:31 AM
how about checking the adjustment of the two shifter cables?
That's where I would start
04-04-2014, 06:47 PM
Will not shift into reverse
Just wanted to thank you guys. My boxster wouldn't shift into reverse, and after reading the thread I was able to remedy the problem, I used the zip ties. Works fine now. Thank you.
Sid
