02-29-2012, 03:06 PM
#1
Xenon light kit problems
I installed the HID kits and they work fine but are apparently drawing too much power. I installed them on the high and low beams. When I turn the high beams on they work but my battery and oil warning lights come on and the radio shuts off. Any suggestions?
02-29-2012, 03:20 PM
#2
Your problem is not necessarily one of the lights drawing too much current. We have seen all sorts of electrical problems caused by cheap aftermarket HID “kits”, ranging from various malfunction indicator lights on the dash, audio system issues, shorts, electrical fires, you name it. This one of several reasons we list all aftermarket HID installs as a “deduct from price” item when we do a PPI.
Most of these kits are typically sourced out of the Pacific Rim, mainly China; the quality is questionable, as many times are the components, which also turn out to be virtually impossible to get any replacements for. Even the instructions they come with are often undecipherable. Even worse, in some states the car will not pass inspection with them installed, and can be “ticket bait” for cops so inclined.
Anything really new is invented only in ones youth. Later, one becomes more experienced, more famous and more stupid. - Albert Einstein
02-29-2012, 03:24 PM
#3
Thanks for the info! I had no idea it would cause an issue like this. I'll take them out and keep the original bulbs in.
02-29-2012, 06:47 PM
#4
hit your manual spoiler button and see if that turns off the batt/oil lights
2001 Seal Gray 5-Speed - 2007 Yamaha R6 - 2003 Honda Civic EX - 1999 Nissan Frontier XE - 2003 Coleman Utah
02-29-2012, 06:50 PM
#5
Just push the button when the lights come on?
03-01-2012, 07:42 AM
#6
2006 987
Maybe I'm mistaken, but aren't they suppose to draw *less* power and put out *less* heat?
03-01-2012, 10:20 AM
#7
Same exact problem; I'm going to see if changing the relay for the headlights will make a difference.
SOLD 2001 Boxster S, Arctic Silver, Painted Bumperettes, De-Ambered, Chrome Badging and Emblems
[No longer active on this forum]
03-01-2012, 10:47 AM
#8
I'd bet it doesn't.....................
03-01-2012, 03:34 PM
#9
Appreciate the encouragement
03-01-2012, 04:35 PM
#10
Haha... let me know what happens.
03-02-2012, 01:53 AM
#11
LOLLL yes you are right not only they are three times brighter and consume less energy, they can last up to ten times longer
A comon mistake is made by installing the 55W ballasts. You need the small/slim 35W. Again... they are three times brighter so you'll have plenty of 35W HID to simulate daytime believe me. Just change them and you'll be all good mate.
For info... the new kid on the block at the minute is the XPU model made by CNLIGHT. They are so slim we can fit them in the headlight's back enclosure and there is still room left. Nothing dim, no stereo click-sound, no change in V/AMP when switched on, and they warm-up/light-up twice faster than other ballasts!
HID Ballast,Energy Saving Lamp,China HID Ballast Manufacturer
Hope this helps
03-09-2012, 03:46 PM
#12
Sorry to disappoint JFP in PA but I installed 4 capacitors and haven't had any problems since (although for sure now that I posted this I will indeed...). I bought these for less than $20 shipped.
This picture is from EBAY.
03-09-2012, 05:02 PM
#13
Try as you will, there's no substitute for Litronics !
Don't worry
I've got the microfilm.
03-10-2012, 08:35 AM
#14
You didn't disappoint me at all, changing the relay obviously did not work as you had to add capacitors............
03-11-2012, 12:45 PM
#15
Actually never tried the relay at all after I found these so still don't know.
What I should have said was sorry to disappoint the forum that my efforts won't lend any insight into whether the relay would work.
