Old 02-27-2012, 03:24 PM   #1
Rear control arm replacement
Got the rear control arm from Vertex, pulled the old one out. They are similar but the old one had a kind of nipple or washer in the ball joint that attaches to the wheel housing. One is already attached to the old ball joint. The one from the other side I pulled out is on the right. Do I push this into the new ball joint and install it? It took some force to get it out and it seems to push the rubber boot on the ball joint all the way in. That can't be good I'm thinking. IS this the standard for the rear. The front ones didn't have any.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
