Old 08-10-2005, 07:55 AM   #1
K & N
Just purchased a K&N filter for my box s and wanted to know what the latest opinion was on using them. I have read the oil can cause problems with the MAF but I believe the opinion on PCA has changed...I will be putting mine in new so it shouldn't be "over oiled"
Is the K&N's air flow similar to what you would get just by removing the foam layer on the stock filter?
Wanted to get some feedback before I install (or return)...thanks
PA986S is offline   Reply With Quote
Old 08-10-2005, 08:34 AM   #2
deliriousga's Avatar
The oil problem is just when it is over-oiled IIRC. Just make sure there's no oil on the filter that can come off and get on the MAF and I think you'll be ok. Don't expect any more HP, though. I believe that's a myth.
1966 Wife White/Brown Top
Old 08-10-2005, 05:06 PM   #3
tqtran's Avatar
deliriousga is correct:
1) the oil problem is when people reoil the filter. If its a brand new one then you should be find.
2) no hp gains for boxsters
tqtran is offline   Reply With Quote
Old 08-10-2005, 05:51 PM   #4
Thanks for the feedback...I was thinking the same thing in regards to oil in the filter.
I have read many posts about there being no increase in HP although it's hard to believe there isn't some if air flow is truly increased even if minimal...good thing I mostly want to do it for the sound and to put a new filter in. I like to hear as much of the motor as I can...don't even like to use the radio.
Would like to move up to the EVO intake when I have the $...seems like there is an increase with that intake especially with a chip
Old 08-10-2005, 05:53 PM   #5
Wipe it down to get access residue off at initall installation. When re-oiling please allow to dry for at leat 24 hours and wipe down. Key here is oil=BAD.
I thought I would add something here that Imagine auto is doing a group buy on these right now.
I have a de-snorked 2000 S with an EVO intake fitted with the K&N. The butt dyno says it work.
JP-s-in st. louis is offline   Reply With Quote
Old 08-16-2005, 11:42 AM   #6
K&N Installed
Well I installed the K&N filter on Sunday (I wiped it all down as suggested) and I must say there is definitely a difference.
The motor no longer seems choked at 6K and downshifts are smoother due to easier throttle blip.
I am sure it would not show much on a dyno but a definite improvement.
Old 08-16-2005, 01:19 PM   #7
Perfectlap's Avatar
hmm seems risky. I just got the MAHLE airf fileter from PAP-Parts (delivered in one day). No oil required.
THose MAF are NOT CHEAP.
BORN: March 2000 - FINLAND
