Old 01-12-2012, 03:52 AM   #1
Muffler replacement question
I'm replacing my muffler with the stock one. It would the muffler with the U tube on both sides attaching to rear of the Cat. DO I need any gaskets when I replace? Want to make sure I have everything so I don't find myself waiting for a week with the car without a muffler. Thanks.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
Old 01-12-2012, 04:21 AM   #2
Ex Esso kid
If I understand you right you are going back to stock. I'd check the clamps, they should be splined if they retained the factory hardware, you have to separate them after you remove the nut. Other than that there was no O rings or special hardware to complete the connection, just those special clamps which I used on the Dansk and kept, hope that helps.
Old 01-12-2012, 04:50 AM   #3
That helps. Thanks.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
