Old 01-12-2012, 04:21 AM   #2
Ghostrider 310
Ex Esso kid
If I understand you right you are going back to stock. I'd check the clamps, they should be splined if they retained the factory hardware, you have to separate them after you remove the nut. Other than that there was no O rings or special hardware to complete the connection, just those special clamps which I used on the Dansk and kept, hope that helps.
