Old 11-25-2011, 07:21 AM   #1
John99Boxster's Avatar
Rear Defroster help
99 Boxster. PO had a new top installed with Glass. It appears that whomever installed it failed to re-connect the rear defroster wiring. I have looked high and low for these wires and can not find them.
The window does have the connectors attached to it....but no wiring.
How would I go about installing the required wiring and re-connecting the defroster?
I.e where does the wiring originate and what gauge wire, what type of connectors?
1999 Boxster
Ocean Blue Metallic/Savannah Beige | Tiptronic | Custom Rear Spoiler | 17" Turbo twist | Red Brembo Calipers | GAHH Top w/Glass Window | Tinted Windows | Cruise Control | Leather Interior | Heated Seats | Color Wheel Caps | Traction Control | Debadged
John99Boxster is offline   Reply With Quote
Old 11-25-2011, 02:04 PM   #2
I had exactly the same problem. You can buy a wire for 159$ at autotopsdirect or make yours for 10$. The connector on the window are simple flat connector worth 0.99$ for 10. Flexible wire, not too thine is good. I could not find the same plug that connect just beside the driver belt and the roll bar, so I bought simple round connector, one for each wire. Its gettho a little, but I'm gonna change the top next spring with a defrost wire included.
later
wawa
wawa is offline   Reply With Quote
Old 11-26-2011, 02:44 AM   #3
Wawa...Thanks....do you have any pictures?
1999 Boxster
Old 11-26-2011, 03:37 AM   #4
Update.
I now see where the wires originate (behind the drivers seat in a flip up compartment). And if I understand correctly the flat connectors on the window itself are (one positive and one negative).
So that leaves me with 2 questions..
1. Where could I find the connector (looks like 2 pin male) that plugs into the flip top compartment. Or how could I rig it?
2. What type/gauge of wire do I need?
1999 Boxster
Old 11-26-2011, 05:17 AM   #5
I used these simple flat 1/4 connector at the window: Wiring Accessories - Camco Term Blue Female Tab 1/4 100
and a bullet terminal near the seat belt : Non-Insulated & Trade - Products - Narva
I think I used 14 gauge but I'm not sure.
Later
wawa
Old 11-26-2011, 01:14 PM   #6
I think I will give it a go with the bullet terminals and wire.....couldnt hurt to try!
If it doesnt work....then I suppose my wallet will be $159 lighter!
Thanks again Wawa.
1999 Boxster
Old 12-15-2011, 06:22 AM   #7
So, I finally got around to rigging up a rear defroster wiring harness.....tired of the frost on the back window!
I used 16ga. wire, 2 flat connectors (attached to window) and 2 female tube connectors (attached to plug-in behind drivers seat).
Tested it this morning and it worked HOWEVER......
It took a VERY long time to clear the window...like 20 minutes!
WHAT DID I DO WRONG?
1999 Boxster
Old 02-19-2012, 04:52 PM   #8
Where I got my wiring harness
I just received a wiring harness that I found on stuttgartclassicparts.com and I only paid $13.69. It did takes 6 weeks to get it but it worked perfectly. Although I will need to make a extension for the second wire that goes to the other side of the window. This harness is made for a hardtop. maybe there is a way built in to the hardtop. The part number is 986.612.081.01.
Direwolf is offline   Reply With Quote
