I had exactly the same problem. You can buy a wire for 159$ at autotopsdirect or make yours for 10$. The connector on the window are simple flat connector worth 0.99$ for 10. Flexible wire, not too thine is good. I could not find the same plug that connect just beside the driver belt and the roll bar, so I bought simple round connector, one for each wire. Its gettho a little, but I'm gonna change the top next spring with a defrost wire included.
later
wawa
