Old 11-06-2011, 07:08 AM   #1
car dead wife mad
engine will not start . starter turns over engine but no start. turned key off but dash lights stay on. ran great 2 days ago ? thanks for your help on this !
milliemax is offline   Reply With Quote
Old 11-06-2011, 07:20 AM   #2
tnoice's Avatar
I think you have a bigger issue that the car will not start..........the wife is mad.
Lov'n my boxster!
2013 Lexus IS350awd
2007 Toyota FJ Cruiser
2004 Porsche Boxster S
tnoice is offline   Reply With Quote
Old 11-06-2011, 08:09 AM   #3
Matt
MileHighBoxster's Avatar
I'm not sure why the wife would be mad because the car won't start. If it turns over but won't ignite it's either: fuel, air or spark. Start with one and make sure you have all three. Start with your gas, it's easiest. Dash lights stay on for a while after turning the car off.
MileHighBoxster is offline   Reply With Quote
Old 11-06-2011, 08:20 AM   #4
You should look for a shop thats willing to lend you a spark tester. Spark testing is super straightforward :P
Mrmaddbrad is offline   Reply With Quote
Old 11-06-2011, 08:21 AM   #5
tonycarreon's Avatar
what do you mean by dash lights? you mean the odo? or the "idiot lights"?
have you replaced the ignition switch?
could be starter...
Boxster S Starter Issue - YouTube
Old 11-06-2011, 08:22 AM   #6
Chuck W.'s Avatar
With the 993s there is an issue with the DME relay. This is the module that controls the fuel pump. I wonder if this is also an issue with Boxsters. Keep us posted. Oh, and good luck with the wife; happy wife, happy life.
1995 Porsche C4 Cab
Old 11-06-2011, 08:46 AM   #7
Porscheectomy
Did water leak into your interior recently?
Old 11-06-2011, 09:12 AM   #8
Thank you all for helping. No water, garage kept. no key switch done that I know of. starter turns engine but no start. lights on dash were clock and another one , not idiot lights. I know there is a delay, but waited and then disconected the battery. Wife mad because she loves to take the car any time she can.
Old 11-06-2011, 11:24 AM   #9
thom4782's Avatar
My guess - fuel pump. These fail with no warning. The engine will crank but the engine won't fire. A couple of weeks ago, I drove mine to doggie daycare, dropped the pooch off, and went to start the car. Forty-five minutes later, the car was on a flatbed to the shop. They popped in a new pump and the car fired right up.
Old 11-06-2011, 11:56 AM   #10
My thoughts also. No smell at the exhaust. Did just try to install new ignition switch. The spare new one is defective. It is 45 degrees off on rotation to line up with slot . Played for 2 hours aligning slot (off-on-start) Made in god knows where, can someone help!!! uro parts 4a0905849b A miserable afternoon. My wife keeps asking if it is fixed yet. 99 2.5 90k 3rd owner garaged all records Thanks to all, Max
Old 11-06-2011, 12:17 PM   #11
J Tinsby's Avatar
Better to have the car dead than the wife!
Hope you get it sorted.
"Never force it.... get a BIGGER hammer!"
J Tinsby is offline   Reply With Quote
Old 11-06-2011, 03:40 PM   #12
Try spraying wd40 (not starter fluid) into the intake, if it catches for a second, then you know its a fuel problem. No catch, its the spark.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 11-06-2011, 07:33 PM   #13
Topless's Avatar
Sounds like the ignition switch is the culprit still. Look there first. Power to the starter but not the ignition module.... ding ding ding.
Old 11-07-2011, 06:03 AM   #14
I thank all of you for helping. New fuel pump on order. Also tried to order a key switch from Porsche but was told to go after the relay in the trunk area which is controled by the box under the seat. This controls the fuel injection ? Yikes ? I did bypass the fuel pump relay with a jump wire and did not hear a a pump running. There was current draw on the jump wire as a little spark occured each time of connection. So.. the europarts.com key switch was a bust, no pump noise with power to pump. Taking Advil after the key switch afternoon exercise. Thanks again to all of you. Wife calmed down and took the Volvo. Max
Old 11-07-2011, 03:22 PM   #15
OK ! Tnoice-nice car ! Chuckw-Porsche told me to check DME relay ! Thom4782-got one on order ! Jtinsby- You got that right !!! San Rensho-got no one to help me on this--yet !! Topless-ordered new original Porsche switch, no more nock-offs. For all Boxter owners go to The schillings.com or boxter relay charts and print off a copy to keep !! Thanks again to all of you. Car still ---Dead.. MAX
Old 11-08-2011, 01:02 PM   #16
CAR RUNNING ! Thank you all for your help. Each and every one of you were helpful. Thom4782, special thanks to you ----Puel pump ! Ordered on Monday AM got it today at 3 pm. Installed and she runs great again! I am happy to have found this forum. Thanks again to all of you . Max
Old 11-08-2011, 03:17 PM   #17
Sorry FUEL PUMP ! VDO oem $ 216.95 delivered and done with this problem.
Old 11-08-2011, 05:06 PM   #18
Glad you got the car running again with minimal expense and aggravation. I believe someone noted not to let the cars get too low on fuel, as the fuel also acts as a coolant for the pump. I try to never let mine go below 1/4 tank.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 11-08-2011, 05:10 PM   #19
Porscheectomy
Although there is a cooling effect from the fuel, putting the pump in the tank is a relatively new practice. Before the mid-80s, it was rare. So I doubt the cooling from fuel is crucial to the pump's life.
Old 11-08-2011, 05:52 PM   #20
DenverSteve's Avatar
Good call MileHigh. Exactly right.
Denver Steve
DenverSteve is offline   Reply With Quote
