Old 07-04-2005, 09:57 PM   #1
UPGRADE or REPLACE Brakes
My rotors are gone. I have less then 22mm on them. According to some research, this is below the minimum thickness.
I have a 98 boxster, and my ABS light is on. Obviously.
I'm gonna need new rotors, but at the same time I want to upgrade to something else. Will it be worth it?!
I found some used from a 2000 boxster TYPE S caliper and rotor set for $1000, but new stock NON TYPE S will cost about $400-500 for all 4. What would you guys do?
I'm trying to save some money here, but at the same time, I think I'm missing out on a pretty good deal.
ralegen is offline   Reply With Quote
Old 07-05-2005, 05:40 AM   #2
My mechanics says my rotors wil have to be changed next time around... I'm going with Zimmerman cross drilled. Not expensive, no caliper exchanges to do, same brake pads type will be used (Textar) and braking should improve with the gas release and cooling the drilled rotors provide.
Old 07-05-2005, 06:45 AM   #3
Brucelee's Avatar
Talking
Not sure why you would trust used brake parts, I know I would not!
Just a preference issue I guess!
Old 07-05-2005, 06:46 AM   #4
Brucelee's Avatar
Talking
BTW-If you don't mind driving an hour or so each way, I have an excellent brake man here in Carlsbad. I can also get you an attractive price.
Let me know.
Old 07-05-2005, 07:33 AM   #5
Richard, I think you misunderstood my post. I would be using NEW Textar pads that are identical to the ones I have on the car now... I like the brand. New rotors always deserve new pads...
Old 07-05-2005, 07:55 AM   #6
Mid-America has the Zimmerman rotors. http://www.tweeks.com/shop?frame=8.2298
If you find a slightly better price ask for me and I will match it for you.
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
Old 07-05-2005, 08:33 AM   #7
Tirerack has some good rotors listed. They are slotted instead of cross-drilled so you won't get the cracking. They have one that's Cryogenically frozen for greater durability and they don't cost a fortune.
Rainforest01 is offline   Reply With Quote
Old 07-05-2005, 04:02 PM   #8
Sounds good guys. Thanks very much.
BruceLEE, thanks for your offer. However, I plan on installing them myself, so I don't think I will need your brake guy, unless his parts are cheap!
I found some crossdrilled Zimmermans for ~$110 each FREE SHIPPING. Also, I'm going with Hawk HPS brake pads for about $104 each set for F & R. FREE SHIPPING also. total of about $650 or something.
Old 07-05-2005, 04:53 PM   #9
check ebay, send you a link for example, 4 for 304$+50$s/h+choose color
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33564&item=7983650786&rd=1&ssPageName=WDVW
zagit is offline   Reply With Quote
Old 07-05-2005, 06:15 PM   #10
Brucelee's Avatar
Talking
Let us know what you do and how it all turned out!
Good luck.
Old 07-06-2005, 06:16 AM   #11
Send a message via AIM to jiggysubman
any ever tried a couple of different brands/setups? Give us some input!
Never use a big word where a dimunitive one will suffice.
97 Guards Red
82k miles
jiggysubman is offline   Reply With Quote
Old 07-06-2005, 09:59 AM   #12
I plan on getting these. This guy isn't to far away from me, and I confirmed that he will allow my to pick it up.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2475081543&sspagename=ADME%3AB%3AAAQ%3AUS%3A1
This along wilth some HAWK HPS brake pads. This ebay selller also had some cadmium plated brakes also; are these well worth it?
Also, how's everyone with Textar brake pads? I heard that they squeak a lot; whereas for the HAWKs, I've heard nothing but good things.
Old 07-06-2005, 10:19 PM   #13
donv's Avatar
Not the same application, but I recently put new Hawk HPS pads and Brembo rotors on my Subaru and have been happy with the result. Better feel and performance, but the starting level is not nearly the same as with the Boxster. Let us know how they feel in the Boxster...
2001 Lapis/Black/Black, PSM, Rear Speaker Kit, Optima...
donv is offline   Reply With Quote
