Old 10-23-2011, 03:29 PM   #1
Ex Esso kid
Rust Retardants
Any of you salt drivers have any tips for coating metal against the winter corrosives? I know Scoir (sp) once told me he had the shiz for rust protection..
Old 10-24-2011, 07:19 AM   #2
I have good results with POR15 on some of my four season vehicles in the past.
matthewb is offline   Reply With Quote
Old 10-24-2011, 12:05 PM   #3
laphan's Avatar
I used POR15 and rust bullet before. They both are great...
laphan is offline   Reply With Quote
Old 10-24-2011, 02:02 PM   #4
Ex Esso kid
thanks dudes
Old 10-24-2011, 07:38 PM   #5
POR-15 is the best I have found in over 40 years of fighting rust (I still have my '71 BMW 2002 that I bought new in '71, so I've had plenty of experience).
The reason this stuff works is because it actually uses moisture from the air to cure and has no solvent to evaporate as do most other products. You also don't have to remove all of the rust before applying it, just any that is flaking, etc... Use their original formula (black gloss) and you will be amazed at how well it stops the rust.
Also, don't get any on your skin. Once it cures, it's can't be removed with solvent, and can only be sanded off. Ouch!
Regards, Maurice.
schoir is offline   Reply With Quote
Old 10-26-2011, 08:02 AM   #6
What metal are you trying to protect? The Boxster does not have that much exposed metal and what is exposed is mostly aluminum.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
