08-31-2011, 04:22 PM
#1
warning beep when accelerating
I have a 99 Boxster with 44M miles purchased last year. Everything works great. But just last week when cruising at highway speed, it would beep 2 times (same beep as seatbelt warning) for no apparent reason, no warning lights would show. I noticed after an attempt to get it to do it again, everytime I accelerated alittle harder than normal it would beep again, I could get it to do it everytime. I haven't noticed anything else dffferent, everything still runs fine no warning lights, no other apparent causes. Anyone got any ideas?
08-31-2011, 04:26 PM
#2
have you ever replaced your ignition switch?
(i think you mean 44,000 miles, not 44,000,000 miles...)
08-31-2011, 04:36 PM
#3
M is roman numeral for 1,000 not million.
08-31-2011, 05:18 PM
#4
If your car has the ...
... OBC (On Board Computer) the speed chime is probably activated.
If that's the case it chimes, not when you accelerate, but rather when you pass the set speed.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
09-01-2011, 04:54 AM
#5
09-03-2011, 10:15 AM
#6
You can set the speed to alarm at whatever speed you want or turn it off in the on board computer
2001 Boxster S 3.6, 2003 E46 M3, 94 968 Cab, 80 911 Weissach Edition, BMW 1200 CLS
09-03-2011, 11:35 AM
#7
I had my '98 for a month before I figured out the damn thing would chime every time I went over 79 mph. As has been said, you can set it for any speed you want, or turn it off.
