Old 08-24-2011, 03:25 PM   #1
986 Horn Malfunction Wiring Assembly
The horn on my 1999 Boxster isn't working. I looked at the fuses and realized the horn fuse was fried so I replaced it. Now when I press on the horn, I hear a slight clicking sound, like turning on a light switch but softer, coming from the steering assembly.
Anyone have experience with this clicking noise before or repairing the wiring assembly for the horn?
Symptoms started last summer when the horn would go off intermittently without being touched. I jammed a card in the steering wheel underneath the airbag and it would stop. Looks like the fuse blew since then but I never noticed until it failed safety inspection today.
99 2.5L Boxster: 135,800 miles, AVIC-Z2 In-dash navigation/DVD receiver w/bypass switch, made and installed Pedro's hi flow air intake, custom laser engraved wind-stop, hacked convertible top relay, de snorkeled.
Pianohawk is offline   Reply With Quote
Old 08-24-2011, 04:23 PM   #2
I just had some issues with my battery.
I found out that one of the symptoms of a battery that isn't fully charged is the HORN WORKS INTERMITTANTLY!!! I had this symptom and it has since gone away.
Check out your electrical system, specifically the battery and the alternator. A shop can put an electrical monitor on your car and tell you if your battery is fully charged, if it is holding a charge, if there is a draw on your battery that shouldn't be there and if the alternator works.
A bad battery could be the culprit. It's possible that you have an actual short or something (sounds like it), but don't rule out the same issues I had.
SOLD - 2002 Boxster S - PSM, Litronics, De-ambered, Bird Bike Rack, Hardtop, RMS leak...
fatmike is offline   Reply With Quote
Old 08-24-2011, 07:26 PM   #3
Same problem... haven't really looked into it. My auto cancellation for my blinkers has failed as well. Probably related but haven't looked into it yet.
Jonny Wonder
1999 Porsche Boxster 5 Spd
Stock, with GAHH A5 Glass top.
Previous Toys:
2005 RX-8, RIP
1989 GTA, 5 Speed, Procharger Supercharger and 2 Core Intercooler, 1 3/4" headers, 3" Flomaster Exhaust, cat-delete, digital ignition, bigger fuel injectors
Oaktown 986 is offline   Reply With Quote
Old 08-24-2011, 10:12 PM   #4
Lil bastard's Avatar
If you have the standard 4-spoke wheel, the problem is failed bushings on the airbag frame - notorious weak point. Easy replacement and it'll fix your issues.
Use SEARCH to pull up the procedure.
Cheers!
1976 BMW 2002
1990 BMW 325is
(gone, but not forgotten)
Old 08-25-2011, 06:07 AM   #5
Yup, he is right.
My horn also beeps, but it happens when I go over bumps, brake hard, or accelerate quickly.
I took the fuse out so that it stops bothering me.
Porsche mechanic said the contacts, or bshings in the steering wheel are broken. The Porsche dealer wanted to charge me $360 to fix it in parts and labor. I did not want to spend the money so I am just living with out it.
00 2.7 5SPD MT
ProjectM96 is offline   Reply With Quote
Old 08-25-2011, 07:04 AM   #6
pk2
Originally Posted by ProjectM96
Yup, he is right.
.... $360 to fix it in parts and labor. I did not want to spend the money so I am just living with out it.
There are several different DYI's around to repair the bushings your self. It can be as easy as using black, silicon gasket sealer on top of old bushings (the way I did mine 5 yrs. ago).
Regards, PK
http://img87.imageshack.us/img87/163...58x6ir4.th.jpg
99 Supercharged 2.5L
pk2 is offline   Reply With Quote
Old 08-25-2011, 07:18 AM   #7
Regards, PK
The DIY repairs have not proven to last in all cases. A replacement retainer frame is only like $60 (at last check), so it's not worth jerry-rigging it.
Cheers!
1976 BMW 2002
1990 BMW 325is
