Old 08-24-2011, 04:23 PM   #2
fatmike
I just had some issues with my battery.
I found out that one of the symptoms of a battery that isn't fully charged is the HORN WORKS INTERMITTANTLY!!! I had this symptom and it has since gone away.
Check out your electrical system, specifically the battery and the alternator. A shop can put an electrical monitor on your car and tell you if your battery is fully charged, if it is holding a charge, if there is a draw on your battery that shouldn't be there and if the alternator works.
A bad battery could be the culprit. It's possible that you have an actual short or something (sounds like it), but don't rule out the same issues I had.
SOLD - 2002 Boxster S - PSM, Litronics, De-ambered, Bird Bike Rack, Hardtop, RMS leak...
fatmike is offline   Reply With Quote
