Old 08-10-2011, 05:56 PM   #1
DenverSteve's Avatar
Biggest Surprise Repair Cost
I know these are Porsches and they can be costly little buggers to maintain but....... I took mine in today for a minor and a couple of days ago I developed a small leak in the coolant reservoir which I had them look at. They found a hairline crack in the tank and to replace the small tank - including labor of course - it is going to be $850. WHAT!!!!
Yep a 200+ dollar part plus labor.
What was the biggest single repair cost that totally surprised you? Of course it's proportionally not as bad as the $350 replaced/reprogrammed key fob I had to get a while back.
Denver Steve
DenverSteve is offline   Reply With Quote
Old 08-10-2011, 06:13 PM   #2
As you see in many threads on the forums, it really pays to be a DIYer.
(Unfortunately, for the fob one, it wouldn't have helped. Unless you had individual buttons that quit working, as it's cheap and easy to replace them.)
Old 08-10-2011, 06:34 PM   #3
Coolant tank when I bough it (covered by dealer) had a receipt of $1200 and a failed DIY alternator swap cost me $800. Those have been the only repairs so far (not counting a new MAF).
stateofidleness is offline   Reply With Quote
Old 08-11-2011, 03:41 AM   #4
Back, shortly after getting my Box, the alternator went belly up on me. Having decided the day I bought the car (July, 2005, IIRC) that I was going to do as much work on my own as possible, I then decided "Well...here we go!" Pulled out the Bentley and went to work. The alternator DIY went well (spent like $95 locally to get the old one refurbished), but then I discovered my one mistake: I had taken out the passenger seat WITHOUT disconnecting the battery. Soooo, I had a CEL for the airbag.
The local Porsche stealership was only too happy to help out. To "Check airbag and reset the check engine light" (I only wanted the latter done), they charged me $100! (More than the alternator work had cost me!!!)
Still worthwhile, no doubt, having read what those guys charge to do the alternator start to finish...
Old 08-11-2011, 06:50 PM   #5
Porsche "Purist"
Paul's Avatar
Every DIYer should seriously consider a Durametric, they pay for themselves pretty fast.
1987 924S. 2002 996TT. PST-2
Old 08-11-2011, 07:03 PM   #6
Pat
Wait, what? I'm in Littleton, and I'd be shocked if the shop here charged that. Where did you bring it?
-Chuck Patterson
Old 08-11-2011, 07:13 PM   #7
high cost
Had a tiny oil spot on the garage floor. Drip was coming from right side near axle. Dealer dignosed leaky valve cover gasket. Estimate to fix........$900.00.
Luckily I still had a month left on the Used Certified Warranty.
04 Boxter S
bartocollector is offline   Reply With Quote
