Old 07-28-2011, 10:16 PM   #1
Removing/installing spark plug tubes
I am in the process of replacing my spark plug tubes because oil has been seeping out. The transom boat plug as suggested by many diy's did not work as I couldn't get it to grip the tube. I just inserted a socket with a handle and cracked the tubes at an angle to get it out (hope that is ok). The farthest one inside on the driver's was the most difficult to remove due to the limited clearance. I'm having trouble reinstalling the tube as it won't sit flush. I used the back end of a screwdriver with full force to try to push it in but it is still protruding slightly. Will this be any issue if I leave it slightly protruding?
Also, I noticed that a couple of the plug connectors had damaged rubber tips. Are they still useable or do they need replacement?
ASpec818 is offline   Reply With Quote
