Old 07-25-2011, 04:19 PM   #1
So you can put 48 ft-lbs of torque on those little 7 mm heads without chewin' them up?? And, regarding torque values, Bentley says
Engine yoke to body 48 ft-lb
They don't distinguish between the nuts and the studs.
Old 07-25-2011, 06:24 PM   #2
Pat
Yoke to body = 48
Nut to stud = 34
"Of all the extreme sports I've ever participated in- windsurfing, kite boarding, wake boarding, tow-in surfing and snowboarding- skiing, for me, made everything else easy."
-Chuck Patterson
Pat is offline   Reply With Quote
Old 07-25-2011, 08:30 PM   #3
You guys are confusing me...
Regarding torque values, this is what Bentley recommends, in full:
Engine mount to engine 34 ft-lb
Engine yoke to engine mount 48 fl-lb
Now, what I've been talking about is the second in the list..my only question is whether they're recommending 48 ft-lb to the stud, or 48 ft-lb to the nut that threads onto the stud. Both are involved in fastening the yoke to the body.
The only 34 ft-lb recommendation is for the bolts that actually go into the engine. That seemed crystal clear, and I've already followed that advice.
Back to the studs mentioned above. With the heads on them at 7 mm, the only wrench I have that's that small is about 4" long. If I'm supposed to crank that to 48 ft-lb, I need to get a longer wrench...I'm not sure I can put almost 150 lb of force on that little wrench, which is what I'd need to accomplish 48 ft-lb. In any case, it just seems to be asking for trouble--I think with that much torque you'd be likely to tear up the wimpy little 7 mm heads. I put 'em in basically pretty much as tight as I could with the little wrench I mentioned and am going from there. (When the nuts are threaded on and torqued to 48 ft-lb, that's gonna put a lot of outward force on the stud threads in the body, which should make the fit pretty secure---I just don't see them coming undone.)
Old 07-25-2011, 10:53 PM   #4
Its 48 for the studs that go into the frame. Then, its 34 for the NUTS that go onto the studs. Very straightforward.
I used a cheap 7mm socket on my torque wrench and I had absolutely no problem getting the torque to 48 on the studs.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 07-26-2011, 05:35 AM   #5
This has largely become a mental exercise for me---I've cranked on enough variously sized nuts & bolts (stripped a few!) to have a pretty good "feel" for what's about right, torque-wise. (With the total inaccessibility of so many of them on Boxster repairs, I've considered tossing the torque wrench into the trash can.) But, I'm sorta having fun with the discussion...here's the diagram:
Now, back to my list from Bentley:
A) Engine mount to engine 34 ft-lb
B) Engine yoke to body 48 ft-lb
C) Engine yoke to engine mount 48 fl-lb
Is it just me, or isn't it clear that "A" refers to Bolts 7 & 8 in the diagram? That's the only torque value in this section of Bentley that specifies 34 ft-lbs.
And "B", to me, seems just as clearly to refer to the fasteners numbered 1 (of which there are actually four total). Inconveniently, Bentley didn't specifically provide separate torque values for the stud and nuts in their description.
Likewise, "C" corresponds to nuts/bolts 2 & 3. Right?
Where do you guys get "34 ft-lb" for the torque setting for the nuts (numbered 1, in the diagram) to the studs??
Old 07-26-2011, 05:43 AM   #6
From the porsche factory manual and Pedro's write up.
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
Old 07-26-2011, 06:25 AM   #7
Regarding the factory manual---unfortunately I can't comment, I don't have it.
Regarding Pedro's write up---read it again. He (quite possibly being smarter than all of us) simplified to the extreme: He just recommends 34 ft-lb for ALL of them (http://www.pedrosgarage.com/Site_3/Install_Front_Engine_Mount.html).
