Old 07-14-2011, 06:33 AM   #1
was cleaning radiator ... and it broke, what to do??? I have work in 8 hours! help!
Hey guys,
I was cleaning my radiators out, following the youtube video . . . when I went to separate the AC radiator from the engine radiator, the tab that holds it on bent, and compressed air has been coming out for like 5 minutes now ...
The little metal tab that pokes out of the front radiator
What is the function of that front radiator (ive read its the AC radiator, I guess it keeps the AC cold??)?
I'm guessing I'll have to replace that front radiator ... is that the only part that I'll need to replace? and will it be a plug and play - hook it up and I'll be ready to go? Like do I need to bleed the system of anything, re-do my coolant or any of that crap?
And finally, where can I get this part other than Porsche? Is it something generic that autozone, or advance auto parts would carry?
On the bright side, I cleaned a ton of crap off of the drivers side and didn't break the tab
fedekz986 is offline   Reply With Quote
Old 07-14-2011, 06:51 AM   #2
that is your AC condenser. you can drive the car without it, but don't run the AC. you will need to replace it & have the system re-charged.
i have a good condenser you can have for $60+shipping; i can send it out today. PM me if you want it.
insite
'99 Boxster
3.4L Conversion
Old 07-14-2011, 07:02 AM   #3
You got my response on Pelican already.
Just want to say that's one heck of deal offered by insite. Cheap fix for an expensive mistake!
seventythree is offline   Reply With Quote
Old 07-14-2011, 08:25 AM   #4
Jaxonalden's Avatar
You do have another avenue...call any local radiator repair/air conditioning service center and ask if they can weld aluminum. It’s a simple fix and then just have the AC system recharged. Same holds true for radiator repairs. With luck you’ll have the crack repaired and recharged in the same shop.
Old 07-14-2011, 08:36 AM   #5
condensers looks anodized to me. poisonous to weld; shops aren't supposed do do it....but some do.
insite
'99 Boxster
3.4L Conversion
Old 07-14-2011, 04:11 PM   #6
Wow! Heck of an offer by insite which you should definitely take him up on. The left condenser on my 997 went recently and it was a $950 repair job ..... but all was covered by my Porsche warranty . Recharge will cost some but shouldn't be too much.
Good luck
