Old 06-30-2011, 09:41 PM   #1
Replaced clutch. Now there is transmission oil leaking
I replaced the clutch at the weekend. Everything seems to be smooth until I noticed there was some gear oil lying under the car. I inspected it again tonight and noticed there is gear oil coming from where the transmission and crankcase connects. There should not be oil from here.
I replaced main shaft seal on the transmission, which I presume is the issue. Why would this be? I installed as the 101 book said and it looked secure/like before.
Thoughts?
rdougan is offline   Reply With Quote
