Old 06-20-2011, 12:26 PM   #1
2001 RUF 3800S
violametallic-S-'s Avatar
Durametric not working red light on. Due to ecu flash?
I'm pretty sure i used the cable after ecu flash. I called Durametric and they said it's probably ground issue. Didnt help me that much.
What to do?
IG: RUF3800S
violametallic-S- is offline   Reply With Quote
Old 06-20-2011, 12:44 PM   #2
We use a Durametric unit on cars with all kinds of re-flashes, never had an issue. Are you sure the cable is seated in the OBD II port? There have been a lot of "problems" reported getting simple OBD II scanners to read because the plug was not seated, issue went away once it was...............
Old 06-20-2011, 12:57 PM   #3
2001 RUF 3800S
I'm sure it's in properly. Green light is on when it's plugged in, as soon as I pick "dme" or "abs" to be scanned, red light comes on then I have to unplug the cables and reset program to give it another shot.
IG: RUF3800S
Old 06-20-2011, 05:06 PM   #4
Jager's Avatar
Does it make a difference if you plug it in before or after you turn the ignition key? I always plug-in after I turn the ignition on or start the car.
Old 06-20-2011, 05:13 PM   #5
2001 RUF 3800S
no tried it every which way
IG: RUF3800S
