Old 06-13-2011, 08:01 AM   #1
Oh no! Buffed through the paint.
I did some successful repair on my bumper cover recently and that gave me the (over) confidence to tackle a bunch of stone chips on the front trunk lid. I globbed some touch up paint then sanded flat up to 2000 grit, then buffed & polished. It looked pretty good but I realized that I didn't get the globs flat enough so I went back and sanded them again with a wood block to act as a sanding block. Then I buffed again and went too far.
I have some color matched aerosol base coat and of course clear coat too but it's hard to do a very small repair with them. The droplet size is kind of coarse and the spray pattern is too big. I can mask off so that the paint only goes onto a small space but it leaves a ridge when you pull up the tape and feathering the edge with fine sandpaper seems to leave a little bathtub ring around the repair that is noticeable.
I was thinking of buying an airbrush and thinning out some touch up paint to attempt a small repair where I blended the patch out. I've never heard of an airbrush being used on cars except for custom flame jobs, etc but I've convinced myself it might work. Anybody ever done something like this or have tips for small scale paint repair?
Dale_K is offline   Reply With Quote
Old 06-13-2011, 08:25 AM   #2
Porscheectomy
Swamy says: I see a body shop, a repainted hood, and $500 removed from your bank account in your future.
Old 06-13-2011, 08:43 AM   #3
Lil bastard's Avatar
Using an airbrush is very doable. You'll be able to feather the edge way back away from the affected area to where you have thicker paint. Dilute the paint and plan on several coats. Don't prep the area away from the problem (just the problem area) and the 'overspray' won't adhere well, making removal easier.
Then, use only a random orbital with med-to-fine polish and foam pad to smooth it all out - forget the sandpaper. This will take a lot more time, but won't get you into trouble again. Same with the clear. FYI - shoulda used a foam sanding block, lots of soapy water and pre-soaked the Wet or Dry paper for 24 hrs.
If you take your time, it will be invisible when you're done. Suggest getting an old hood from a junkyard, placing it on a couple saw horses and practicing your technique beforehand. And old hood can be had for as little as $10 from a Pick&Pull.
If you don't come by 500 clams easily (especially in this economy), this is worth a try. But, the key is PATIENCE - you'll be rewarded for it in the end.
Cheers!
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 06-13-2011, 01:54 PM   #4
TriGem2k's Avatar
Send a message via AIM to TriGem2k
Agreed with the Bastard.
If done properly airbushing works wonders. I personally have never attempted it however I have a buddy that has done TONS of work on my cars to rid them of stone chips and blemishes with an airbrush.
TAKE YOUR TIME!
Good luck!
http://i46.tinypic.com/2qx0rqs.jpg
2001 Boxster Artic Silver / Black Interior
-GT3 Front Bumper w/ Lip
-Side Skirts
-Gemballa Exhuast and Cats
-O.Z. Racing 18" Wheels
--18X8.5Front 18X10 Rears
-Michilen PS Tires 225/40/18 & 285/30/18
-5mm Rear Spacers
-Porsche Door Sills
-H&R Springs
-Powerflow Intake
-B&M Short Shifter
-Pioneer Avic-F90BT Navigation
-Focal Polyglass 165VR3
-Alpine PDX 5 Amp
-Bose OEM Subwoofer & Midrange
-Audio Controld DQXS (DSP)
TriGem2k is offline   Reply With Quote
Old 06-14-2011, 06:41 AM   #5
I should be shot. I went down to Walmart and bought a selection of colored sharpie marking pens. I "painted" the buff mark with a blue pen. It's really half-assed but at least it doesn't leap to your eye the way it did before. I'm going down to Hobby Lobby and check out the airbrushes.
Old 06-14-2011, 07:23 AM   #6
pk2
You might try this; sand with something like 1200. air brush color, airbrush a larger spot with clear then, when the clear is tacky, melt/blend in the edges with straight thinner. When it's good and cured you can sand and polish if you feel bold. Gently please.
Don't yell at me if you mess it up please,
PK
http://img87.imageshack.us/img87/163...58x6ir4.th.jpg
99 Supercharged 2.5L
pk2 is offline   Reply With Quote
