02-12-2009, 06:10 PM
#1
How do I put car in service position with GAHH top?
I didnt consider this to be a problem when I went with the GAHH top, but last week I tried to clean my MAF and found it really difficult to get the top into service position. It seems with the glass rear window, the top wont move over the roll bars from the back to give clearance into the engine compartment.
Does anyone know a trick to this??
Thanks!
Joe DiMonte
2001 Boxster S
Triple Black
02-12-2009, 06:28 PM
#2
www.klisstle.com
Joe,
Unfortunately there isn't a trick. Access to the engine (or lack thereof) is the down side to the GAHH glass window top. I've read posts about removing the whole top to get access, but obviously that is an option in extreme circumstances.
I cleaned, and later replaced my MAF with my GAHH top. I've also changed the air/oil separator and replaced the air filter a few times. So access is limited, but it isn't the end of the world.
Best of luck.
ddb
02-14-2009, 04:34 AM
#3
I am installing another GAHH top next week. I am told they have modified the top to look like the new oem tops. I am not sure if the size of glass has changed. I will let you know. I have seen pictures of the Robbins top. They supply a strap that holds top forward. However, the dealers, (who I subcontract for) say the GAHH top with the glass window is difficult for air filter change, but not impossible. Some guys just unbolt the frame.
02-17-2009, 08:05 AM
#4
I got a Robbins top with the retrofit glass and it is much more difficult to put it in service mode. The robbins top came with a velcro service strap that goes around the top assembly and tightens and pulls it up and a bit more out of the way. Did your GAHH come with a Service Strap?
TimAustinW
http://i226.photobucket.com/albums/d...ignature-1.jpg
02 Seal Grey, NHP Headers w/ Highflow Cats/2ndary Bypass Pipes, smoked side markers/3rd brake light, exterior match interior trim, 986 Lloyds Mats, 986 deck lid emblem, arctic silver intake grills, ipod link, painted calipers, Glass Window Robbins Top with defroster kit, Bose Sound System, Leather lower door panels, Console Lid w embroidered crest; Stainless door sills; Painted Bumperettes; Custom Hood Crest
02-17-2009, 09:47 AM
#5
www.klisstle.com
Tim,
The GAHH doesn't come with a service strap. I can see how having one would be very helpful because the raised, rear part of the top doesn't want to stay up, out of the way very well.
So how does the strap work? Does it just attach to the edge of the rear part that raises with the other end attached to the front of the top? I may try and make one or even purchase one from Robbins if it will work on the GAHH top.
For those considering purchasing a glass retrofit top, this is a down-side to having one (as well as a smaller window). But IMO it isn't enough of a pain to change my decision. I was able to do the work listed above without major issues. When I factor how often I even open my engine compartment versus all of the lowering/raising the top without worries it is an easy decision. Not to mention the electric defroster and a more upscale look of a glass window.
ddb
02-17-2009, 11:28 AM
#6
It's always been the 'deal-breaker' for me.
02-17-2009, 06:56 PM
#7
No service strap that I know of. I should Email GAHH and see if they have anything like that.
It is definately not a deal breaker though. I really only get under the hood to clean the K and N and MAF. Everything else seems to be bottom side.
thanks,
Joe DiMonte
2001 Boxster S
Triple Black
06-01-2011, 12:30 PM
#8
Service Strap - GAHH
Agree that getting the top out of the way is annoying (I used a auto-racheting strap from an auto store) but learned since that GAHH has them:
Hi David,
Service strap is available for $25.00, they are in stock for delivery.
Regards,
Jack Dekirmendjian, VP
GAHH Automotive
11128 Gault Street
North Hollywood, CA 91605
Tel (818) 767-6242 x100 (INTL')
Tel (800) 722-2292 x100 (USA)
Fax (818) 767-2786
jack@gahh.com
www.gahh.com
