Old 09-12-2011, 04:53 PM   #21
97 Boxster's Avatar
It worked like a charm for me. Thanks guys/gals.
Oh, I did the drivers side (thought the noise was coming from there) and itturns out it was the passenger side. Did both.
2006 Hummer H3 - RED 76k mi - LIFTED - 3rd row custom seating on 35's and a manual tranny.
1997 Boxster Guards - RED 86k mi - 19" Lobster Claw Wheels on Conti's , Porsche side decal for extra "speed", manual tranny -signed by Hurley Haywood
Phoenix, Arizona
97 Boxster is offline   Reply With Quote
Old 09-13-2011, 05:07 AM   #22
97 Boxster's Avatar
Man I had a nice "squeak free" ride in to work today. If anybody is having this squeaking/spring issue then try this out. Thanks INSITE
Phoenix, Arizona
Old 06-11-2012, 11:03 AM   #23
It does work like a charm, for about a week in my case. If I remember when I have the car in the air, I hit the boots again with WD40, but usually I just live with it. Its only really loud going over slow rises or dips, like driveway entrances.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 06-16-2012, 05:34 PM   #24
Followed your advice from 05-31-2011 post to newjersymike about nylon ball joints causing loud squeaks. Problem has plagued my 1997 boxster off and on for several years. Tried your WD40 suggestion with instant success for the right front wheel joint! Thank you !
Charlie
Charlie is offline   Reply With Quote
Old 08-14-2012, 04:02 PM   #25
Quick Fix Question
Hi... I seem to have the same problem... 99 986, just started happening after 3 hour drive on windy road..hot day etc,,,, car seems to handle fine but squeaking on front passenger side is very bad...smaller squeak when wheel moves vertically over say a bump... but really loud when turning the steering right or left ( unbearable ), so my question is assuming it's the bushing, in the ? control arm? Sway bar? ( Novice here ) is
there an issue with doing this...kinda like taking something for the symptoms of an illness to make them go away... but not curing the diesease...if you get my meaning? is there a chance of some catastrophic failure by just masking the squeak?..ie will one wheel go in one direction and the other in another?
I'm having it put up on a ramp tomorrow, and asked the Mechanic to look over the front suspension / shocks everything...just incase ( just had a set of bielstiens put on the back ) one rear shock was gone... was price but was well worth it.... nice tight ride now.
Any Input anyone?
Paul
Imacman 99, 986
IMACMAN is offline   Reply With Quote
Old 08-15-2012, 06:22 AM   #26
Originally Posted by sasha055 View Post
What to do with the hole after you spray WD40? should it be closed somehow?
I'd find a way to close or tape the hole well. The boot is there (sealed) for a reason. One speck of sand is all it needs to start the problems.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
Old 08-15-2012, 08:38 AM   #27
Theoretical propagandist
Eric G's Avatar
If you clean the surface with a good alcohol wipe and hit it with a touch of industrial silicon it will seal the hole. Cleanliness and adequate time to cure are key.
Old 08-16-2012, 05:31 AM   #28
All Done
Thanks for the response, I Took it to my P Mechanic ( Very hard to find up here in Newfoundland... and his shop is busy with some Targa Racing work for some clients.)
They were very familiar with the issue, they put it up on the lift, and injected the grease, and also did rust check treatments on both left & right suspension parts. It only took a few minutes, didn't charge me anything for it, and it worked perfectly.
I decided to replace the parts on both sides, so I had them order in the arms... they were only $85 each, so I figured it's just as well to replace them both... it will also be an opportunity to check/torque/tighten the front end as long as they have it up in the air.
About a month ago, I had a bad "Knock" on the right Rear, so I had it looked at and the right rear shock was blown, so I had them replace the rear shocks. They installed Bilsteins... was a bit pricey for the shocks... but was well worth it no more Knock/Bang and the ride is great. Replacing the rear shocks was not easy, without the "Porsche Shop Compressing Tool thing-a-ma-bob"... to too big dudes to remove & install them.
Paul
IMACMAN, Newfoundland 99,986 Triple Bl
Old 01-16-2013, 01:03 PM   #29
Hey guys - I am looking to do this as well. What's the best way to access the ball joint area with the car on the ground? I turned the wheel all the way, but it's a tight fit with the wheel on. I can squeeze my hand in to touch the ball joint, but it's tight to do accurate puncture of the joint and put wd40 in.
Also, should I just use the straw with the WD40 can and cut a hole, or is it worth it to try and use a grease gun or something like that?
rondocap is offline   Reply With Quote
Old 01-17-2013, 05:37 AM   #30
Homeboy981
Homeboy981's Avatar
Hi All,
The North Texas Boxster Enthusiasts did this mod at one of our events….with a twist!
Instead of CUTTING on your boots. GET A SYRINGE and INJECT the WD40. Spray it into the cap, suck it out with a needle, tap three times to look like a doctor (optional), and inject into the boot AT THE HIGHEST POINT THAT DOES NOT TOUCH METAL - so as not to foul the needle. There are four locations per wheel.
I go down dirt roads to find houses, this fix has saved my sanity. So far, I have done it twice in a year of ownership and driving dirt roads daily. So once a year may be more then enough.
The trick is to use the needle as it will not leave a major hole like cutting the boot would. Your mileage may vary….but they ARE QUIETER MILES! Enjoy!
Old 01-17-2013, 07:40 PM   #31
mcomet's Avatar
Any chance of more info or pics of those "four locations per wheel"? Syringe idea is great. Where did u get yours from?
Michael Comet - www.comet-cartoons.com
2014 Guards Red Cayman S - PSE - PASM - 20"CC - INFTMT - CONV - etc..etc...
SOLD - 2003 Speed Yellow Porsche Boxster S - LNE IMS - Klisstle Rollbar Cover
mcomet is offline   Reply With Quote
Old 06-15-2013, 01:22 PM   #32
Newbie question (apologies) : Any chance of a pic / description where the ball joint is?
As my first project with the new (2000) boxster - I have taken a look but struggling to spot it. . .
Any help appreciated!
L
Lboxster is offline   Reply With Quote
Old 06-17-2013, 08:14 AM   #33
turn your steering wheel all the way right. look behind the left wheel down low. you will see a control arm that connects the wheel to the car. the ball joint will be at the outermost point of this control arm.
insite
'99 Boxster
3.4L Conversion
Old 06-29-2013, 12:04 PM   #34
Thanks insite- useful pic.
Strangely it seems to come and go. . .returning when I drove today so will give this a go tomorrow and report back!
L
Old 06-30-2013, 04:32 AM   #35
I need to do this as well. When I push the rear corners down, they creak.
'99 Boxster Artic Silver/Red
'14 Subaru Outback
'06 EG Classic
'05 Sportster
Old 07-21-2013, 12:21 PM   #36
So this took me longer than expected - once you have the right tools its easy & works a treat! Zero annoying creak
Started out with a spray can of grease - this was too thin and harder to control: Being close to the brakes I gave up on this plan.
Instead i bought a syringe from amazon and used some thicker grease. Also with the syringe it meant I could do it without taking the wheel off (with my 18" wheels I couldn't see the part on the fronts even on full lock) instead just feeling for the rubbery bit.
As info for others - I used this cooking syringe from amazon : www.amazon.co.uk/dp/B001HZMOII. Pretty well made & did the job.
Cheers guys for the help!
