Old 05-24-2011, 05:12 PM   #1
jaykay's Avatar
Impending AOS problem?
Looks like my AOS has a film of oil all over it. Is this normal disharge or I am in for trouble? I am not sure my hands are small enough to get in there and change it. How do you guys do it??
986 00S
Old 05-24-2011, 06:33 PM   #2
Jager's Avatar
Have you been driving in the swamps again??
What the heck is that on your motor? I have not seen this before... I've seen a little dust but nothing like that... Is that a greenish tint I see?
Jager
Old 05-24-2011, 06:47 PM   #3
jaykay's Avatar
yes the JK machine has just come back from a desert mission.... hence the my post regarding proper proceedures for an engine shampoo
986 00S
Old 05-24-2011, 07:47 PM   #4
oil misting in the top part of the AOS is a sign that the AOS is leaking. Also if the throttle body has a build up of oil in it you should get ready to replace it. It really is not that hard, you would be surprised. maybe an hour of work.
The final sign for me to change it was going from no oil consumption to having to add a quart of oil before an oil change. This happened twice before I finally changed it. Now it is back to normal, with no oil usage between changes.
2002 S
Old 05-24-2011, 08:07 PM   #5
Steve Tinker's Avatar
A real easy way to check if your AOS is leaking is to try and remove the oil filler cap with the engine idling - if the cap is difficult to remove, ie there is a vacuum holding it closed, there is a good chance that you have an AOS replacement in your near future....
2001 MV Agusta F4.
Old 05-24-2011, 11:20 PM   #6
smagerstein's Avatar
If you feel this vacuum Id just change it over, its not expensive to do and saves alot of embarressment when it goes at the supermarket and you leave a mushroom cloud behind you when you drive!
Steven Magerstein
2002 Boxster 2.7 Seal Grey
2008 MB C200k
Past Cars
2006 MB C180k
2005 Peugeot 306
1980 928
2004 Subaru Liberty GT
2000 Nissan Pulsar SSS
smagerstein is offline   Reply With Quote
