Old 04-24-2011, 11:39 AM   #1
Junk in Oil - Help Identify
I haven't been driving my Boxster much (2000 Box S). Yesterday I finally got around to changing the oil again. It's been 19 months and 6,800 miles. I found a LOT of the little olive green rubbery bits in my filter that others have seen before.
But I also found some longer pieces of white rubber.
Just to be safe and investigate further I dropped my oil pan and found a very minimal amount of both types of pieces there. Some of the longer white stuff was stuck up on the oil suction screen though, so I was glad I dropped the pan and cleaned it.
I'm not going to freak out. I only found one speck of metal and just a few specs of the dark brown glassy material from chain tensioners. So I'm guessing that some sealant or o-ring material just got chewed up in the engine. The car is running fine and not leaking oil. I saw someone else suggested the oil filler tube o-ring. That's the only place where I have a tiny bit of an oil leak. I'll have to see if I can take that apart and check it. If the o-ring was bulging inwards I may have snagged it with the dip stick and forced it into the engine... but maybe then it'd just float around in the pan and not get chewed up.
I'm going to run the car for another 6,000 miles and just check the oil filter then, maybe sooner if I lose any sleep over it.
Any thoughts though on the white o-ring like material? Where would that have come from?
Kirk
Old 04-24-2011, 12:14 PM   #2
JTP
I had some of that stringy white stuff in my oil filter too. It's Porsche engine sealant and not much to worry about. I recall there's a thread on the green stuff in someone's oil filter.
JTP is offline   Reply With Quote
Old 04-24-2011, 03:12 PM   #3
I'd be checking a lot before 6k
And doing a UOA at around 1k. Oil is cheap, engines aren't.
Old 04-24-2011, 05:15 PM   #4
I have some of the same white rubber stuff. I haven't worried about it.
Old 04-24-2011, 07:31 PM   #5
the green stuff may be part of your chain tensioner guides.....
insite
'99 Boxster
3.4L Conversion
Old 04-24-2011, 08:14 PM   #6
Looks like food.
Old 04-26-2011, 03:03 PM   #7
Spinnaker's Avatar
Yep, it looks just like this.
It will be nice to know when someone finds out what this stuff it is.
Interesting coincidence, the OP also has a 2000 S.
Old 01-25-2016, 04:46 PM   #8
It sure would be nice if anybody has located the source of the small green bits in the filter. I have looked at all the threads, and they all seem to stop with nobody providing any final resolution of the problem. Is there one or is this still anybodies guess?
first boxster is offline   Reply With Quote
Old 01-25-2016, 06:17 PM   #9
Engine Surgeon
The green comes from the inside of the variable valve timing adjusters. When these seals fail they are ejected from the unit by engine oil pressure. I can tell by the shape and color of them.
US Patent 8,992,089 &
US Patent 9,416,697
Old 01-25-2016, 08:17 PM   #10
epapp's Avatar
Does that mean no more variocam if the seals are ejected?
Old 01-25-2016, 09:01 PM   #11
Engine Surgeon
It's a fail safe, without the seals the unit fails to advance. Check cam deviation and go from there.
US Patent 9,416,697
Old 01-26-2016, 10:03 AM   #12
Thanks Jake. I respect your comments. I will start by checking in that area.
