Old 04-11-2011, 03:51 PM   #1
Motor Mount Fail
Based on all of the advice on the forum, I replaced my front motor mount last week (1999 with 90K miles) and here is what I found:
As you can see, the solid rubber portions of the mount are cracked. The cracks go all the way through. There was really nothing holding the motor in place, it was just kind of rattling around in the mount. I never heard or noticed anything, the car drove and sounded fine.
If you have an older Boxster, you might want to check your mount.
Old 04-11-2011, 04:09 PM   #2
SoK
what replacement mount did you go with?
2001 Seal Gray 5-Speed - 2007 Yamaha R6 - 2003 Honda Civic EX - 1999 Nissan Frontier XE - 2003 Coleman Utah
SoK is offline   Reply With Quote
Old 04-11-2011, 04:47 PM   #3
I went with the factory rubber mount but I upgraded to the four-bolt style. I was worried about excessive engine vibration from the solid and semi-solid engine mounts.
Old 04-11-2011, 05:05 PM   #4
Bobiam's Avatar
There is much on this and other forums about this troublesome mount. Usually causes a 3000 rpm shutter. You were lucky. Changing this mount should be part of PM on these cars.
2001 Boxster, GT3 console delete, lower stress bar, RoW M030 suspension package, painted bumperettes.
Bobiam is offline   Reply With Quote
Old 04-11-2011, 11:14 PM   #5
Gforrest2's Avatar
That's just what mine looked like at about 80k. The only symptom was a "clunk" under hard acceleration when shifting between 2nd and 3rd gears. I too opted for the OEM for the same reasons you mentioned. After replacement, which was a PITA (I don't think I had the car high enough in the air), I had hoped the shifting would be more crisp, but I haven't noticed any difference.
Glen
Old 04-12-2011, 07:36 AM   #6
+2, the front engine mount on my 02S was in the same badly cracked condition at 81k miles and I replaced with a new Porsche engine mount.
PorscheG96 is offline   Reply With Quote
