Old 03-04-2011, 06:29 PM   #1
Can a 3.2 replace a 2.7 w/ no issues?
Can a 2.7 be replaced with an S engine (3.2) with no issues....ie...plug and play? Or are major modifications needed?
silverboxter is offline   Reply With Quote
Old 03-04-2011, 10:22 PM   #2
There are a lot of postings on this forum about swaps. Running a search would be the best way to find out what is needed.
Old 03-05-2011, 06:51 PM   #3
Track rat
Topless's Avatar
The year and DME version are important. Mounts and block are exactly the same. Here is a good guide:
http://www.pelicanparts.com/techarticles/Boxster_Tech/11-ENGINE-911_Engine_Swap/11-ENGINE-911_Engine_Swap.htm
Old 03-06-2011, 01:17 PM   #4
thanks. i read the report but still not sure if i could put an S engine (2001 3.2) into my 2001 base box. does anyone know if this is possible without major modifications?
Old 03-06-2011, 03:22 PM   #5
Track rat
Topless's Avatar
Same year, plug and play.
Old 03-07-2011, 04:24 PM   #6
Porsche "Purist"
Paul's Avatar
I'm thinking you will need to use the clutch and pressure plate from your 2.7 and the air filter/MAF/and tubing from the 3.2.
1987 924S. 2002 996TT. PST-2
Old 03-12-2011, 06:24 PM   #7
I think the dme will have to be remapped.
john330 is offline   Reply With Quote
Old 03-12-2011, 09:00 PM   #8
No remap of the DME required. Both the 2.7 and the 3.2 for 2001 used Motronic 7.2.
Old 03-13-2011, 12:20 AM   #9
Lightning's Avatar
Motronic 7.2 is the ECU hardware version. There are different flash images/firmware for the Motronic 7.2 for 2.7, 3.2, and 3.4 engines. Although it might kind of work with the 2.7 program, the proper approach is to have your ECU programmed with the 3.2 firmware (requires the dealer programmer or a custom aftermarket flash program), but you won't need to change the airbox/MAF/air intake tubing; they are the same.
If you've got an '01, the most important thing to make life plug-and-play is to use an '00 or '01 S engine; otherwise you will have to swap the fuel rails off the old engine, as they changed to non-return fuel arrangement in '02...
Lightning Motorsports
http://www.LightningMotorsports.US
http://www.youtube.com/LightningMotrsprtsUS
Lightning is offline   Reply With Quote
