Old 01-25-2011, 01:03 PM   #1
Wheel size?
Just came across a set of 17" wheels fitted with winter rubber.
The car has 19's now.
Are there issues with simply installing 17"s for winter?
Cheers
eltren is offline   Reply With Quote
Old 01-25-2011, 01:11 PM   #2
97 Boxster's Avatar
I went from 18's to 17's on mine and the ride is awesome. Hopefully it will be even better for you given the diameter difference. Good luck
2006 Hummer H3 - RED 76k mi - LIFTED - 3rd row custom seating on 35's and a manual tranny.
1997 Boxster Guards - RED 86k mi - 19" Lobster Claw Wheels on Conti's , Porsche side decal for extra "speed", manual tranny -signed by Hurley Haywood
Phoenix, Arizona
97 Boxster is offline   Reply With Quote
Old 01-25-2011, 01:36 PM   #3
Always good to
mention the model year and model of the car when seeking an answer. In this case as fitment over brakes whose sizes differ may be a factor.
Old 01-25-2011, 02:24 PM   #4
Sure thing
Good idea!
'99 base Box.
Old 01-26-2011, 07:21 AM   #5
I believe that 16" or 17" wheels were standard equipment on the '99 Boxster. Therefore, your retrofitting of 17" wheels in place of your 19" wheels should work just fine.
CURRENT: Audi TT / Audi A3
PREVIOUS: Porsche 911, Boxster, 968, 912E / BMW 228xi, Z3, 128i, 318ti, 328xi / Audi TT / Mercedes SLK / Fiat 124 Coupe, Spider
VGM911 is offline   Reply With Quote
Old 01-26-2011, 09:25 AM   #6
17" will work fine on the '99 (assuming stock brakes).
16" and 17" were standard for '99. The 18" didn't come along until 2000.
Old 01-26-2011, 05:37 PM   #7
D'oh!!
Mah bad.
Existing wheels are 18", not 19".
Here's the #'s on the wheels being offered me.
- Rim Diameter: 17" Bolt pattern: 5
-- Fronts: width=7"; offset=55
-- Rears: width=8.5"; offset=50
Tires are as follows:
- Dunlap Winter Sport M2 205/50-17 front
- Dunlap Winter Sport M2 255/40-17 rear
As anyone who's read my postings here already knows, I've got a lot to learn.
Educate me please, if you'd be so kind:
What is offset in this context, and how do I determine if there's any conflict with the
(dead stock) '99?
Any issues with those tires?
What's a fair price if it's all in good shape?
Cheers!
Old 01-26-2011, 05:44 PM   #8
As long as the wheel clears your brakes, and you keep the rolling circumfrence the same or reasonably close (by chosing the correct tire size), there is no reason you can't change wheel sizes.
Gator Bite
PCA Cayman Register Advocate
Gator Bite is offline   Reply With Quote
Old 01-26-2011, 06:33 PM   #9
Topless's Avatar
Originally Posted by eltren
Mah bad.
(dead stock) '99?
Cheers!
Those wheels should bolt right on with no issues. Value? $600-$1200 depending on condition.
