Old 01-24-2011, 06:28 AM   #1
I have the LN magnetic drain plug and absolutely no seepage.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 01-24-2011, 10:54 AM   #2
We see a lot of both OEM and LN plugs every week, they are all dry, save a couple that reused the aluminum crush washer...............
Old 01-24-2011, 02:43 PM   #3
What are the torque specs you guys are using? I think (just going on memory since I'm not home) that I used 50 Nm.
I'm not a bit worried that maybe my torque wrench is horrible out of calibration.
Both times were DEFINITELY with new crush washers.
Mike_Yi is offline   Reply With Quote
Old 01-24-2011, 02:56 PM   #4
37 ft. Lb = 50 Nm.........
Old 01-24-2011, 07:01 PM   #5
Now I wonder about my torque wrench.
Old 02-01-2011, 03:47 PM   #6
jaykay's Avatar
no seepage with LN mag plug here
986 00S
Old 02-01-2011, 05:24 PM   #7
BYprodriver's Avatar
I have never had a oil leak from the drain plug OEM or LN. I rarely use a torque wrench to tighten it but I have reused the crush washer & zero leaks. Maybe your sump plate has a small crack or imperfection in the sealing area.
Old 02-02-2011, 10:40 AM   #8
Or his drain plug does......................
