Old 11-02-2010, 07:39 AM   #1
Rear Wheel Bearing replacement questions
Hi,
I'm planning to tackle my rear wheel bearing this weekend and I have some questions:
I'm following instructions on renntech: http://www.renntech.org/forums/index.php?/topic/16729-rear-wheel-bearing-102/page__p__83721
1. Wheel hub, is it held in place only by axle nut? Do I have to undo something to take it out?
2. Ball Joint ... I have no idea what it is, where it is and how to use Ball joint separator.. . Any pointers there?
3. Pulling the axle, Seafeye talk about "a couple of whacks and the whole wheel carrier is able to move freely". What should I "whack"? is it hit the axle and expect it to go in or wheel carrier from the inside and expect it to go out?
I know it's going to be easier to just drop it at the mechanic and 700$ later it will be all good.. However I want to do it myself, it's cheaper and more fun, I really like to work on my car (it's new for me, I never even saw an engine before I bought the Boxster) and in case my other bearings go out I'll be prepared.
Any advice is greatly appreciated
Sasha
sasha055 is offline   Reply With Quote
Old 11-02-2010, 09:00 AM   #2
Schatten-Baum-Mechaniker
this thread shows a ball joint tool in action.
http://www.renntech.org/forums/index.php?/topic/11407-rear-suspension/page__p__79915__hl__%2Bball+%2Bjoint__fromsearch__ 1#entry79915
1. after you remove the big nut, the hub is held by the bearing. look through the procedure and you can see where it is pressed out, destroying the bearing in the process.
2. there are a couple of ball joints in the rear suspension. you only have to separate the one he shows in the pictures.
3. I hit the end of the axle with a brass hammer.
Tommy
2000 Boxster S
1973 914
tommy986 is offline   Reply With Quote
Old 11-02-2010, 11:28 AM   #3
jcb986's Avatar
Here's an article from Pelican Parts on DYI....
http://www.pelicanparts.com/techarticles/Boxster_Tech/40-TRANS-Wheel_Bearings/40-TRANS-Wheel_Bearings.htm
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
Old 11-02-2010, 07:13 PM   #4
I did my rear bearings earlier this year with the hub carriers still on the car. You just need a tool known as the SIR wheel bearing kit. Much less work than what you have planned.
Here is my write up and pictures: http://dorkiphus.net/porsche/showthread.php?t=22358&highlight=Boxster+wheel+bearing
-- John
'00 Boxster S
'86 911 Carrera Coupe (Sold)
Lucky is offline   Reply With Quote
Old 11-02-2010, 07:14 PM   #5
the rears are kind of a pain without the in-car bearing puller set. without it, you'll need to pull off the entire wheel carrier and use a press.
if you need the puller set, you can rent it from me.....
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
Old 11-03-2010, 08:25 AM   #6
Thanks for all the advise!
I have the SIR Bearing Puller I borrowed it from a coworker, however it doesn't have HUB Puller so I'm going to use generic HUB Puller.
I was asking about HUB because with full SIR set you pull the HUB after the axle is out.. with generic puller I'll have to pull the HUB before I take the axle out since it's the 3 legged one that had a bolt pushing on axle.
Sasha
Old 11-03-2010, 11:52 AM   #7
Sasha,
Before you start disassembling anything, be sure that you have ALL the tools that you MAY need, because it's very frustrating to get stuck on the middle of a repair by not having the right tools or the correct spare parts, ask me how I know...
Sasha
Old 11-03-2010, 05:27 PM   #8
Sasha
Actually, the SIR kit can pull the hub. You just use only the small nut on the backside of the hub.
-- John
'00 Boxster S
