Old 10-01-2010, 05:38 AM   #1
Transmission Replacement
Found at the tranny died. Got a 98 box w/tiptronic. Think i'm going with a used one (likely from LA Dismantlers) and try to do it myself.
Questions are...What will fit in there? As in...What years? Can I step up to a boxster S tip and it still be a perfect swap? ...or stick w/only transmissions pulled from 97 & 98 2.5L boxsters?
"You finally got that Nazi-go-cart you always wanted." -Peer
http://i40.tinypic.com/ei6sns.jpg
pompous is offline   Reply With Quote
