Old 08-16-2010, 08:10 AM   #1
Smile Brake Pad Sensor Question
Just replaced my pads yesterday and planned on using the old sensors since they hadn't gone off. However the sensor tip was brittle and I accidentally broke it off when I tried to remove them from the old pads. Since I didn't plan on putting in new sensors I didn't buy any before starting the job. So I just left the sensors plugged in to the electrical system without putting the sensor tip into the pad. Of course now the brake warning lights are on.
Can I eliminate the warning lights by just unplugging the other end of the sensor from the electrical system??
jska is offline   Reply With Quote
Old 08-16-2010, 09:40 AM   #2
Lil bastard's Avatar
No.
The sensor lights when the circuit is broken.
What you can do is pull the sensors, splice the broken wire together again and then just cable-tie them out of the way. This will eliminate the light.
Of course, you won't have a sensor to tell you your pads are worn. One trick is to measure the pads and mark them with a white paint pen at the maximum wear point. That way, you can easily visually check when the pads require changing.
Cheers!
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 08-16-2010, 11:00 AM   #3
So just to make sure I know what you mean.... do i remove what's left of the remaining broke sensor tips and then twist all the wires together?
Do I twist together both inside and outside pad wires together, or just twist together the inside ones and seperately the outside ones?
Thank you in advance for your help!
Old 08-16-2010, 12:37 PM   #4
jcb986's Avatar
Personally, I would buy the sensor...it will save you from scaring your rotor.
Old Hippie Young Heart
Old 08-16-2010, 02:15 PM   #5
Schatten-Baum-Mechaniker
nothing worse than a scared rotor.
Tommy
2000 Boxster S
1973 914
tommy986 is offline   Reply With Quote
Old 08-16-2010, 03:45 PM   #6
I have some old sensors laying around - let me know if you want one. I also have some new ones in the wrapper still if you want new...
Brian
bv1966 is offline   Reply With Quote
