No.
The sensor lights when the circuit is broken.
What you can do is pull the sensors, splice the broken wire together again and then just cable-tie them out of the way. This will eliminate the light.
Of course, you won't have a sensor to tell you your pads are worn. One trick is to measure the pads and mark them with a white paint pen at the maximum wear point. That way, you can easily visually check when the pads require changing.
Cheers!
