Old 08-09-2010, 06:20 AM   #4
jcb986's Avatar
Ok, here goes, It's a manual and what's been posted here is a quick overview. If the Boxster has a good maintenance history that's a plus. If the following has not been done you will need to have it done so you do not encounter a catastrophic engine problem. The IMS seems to be a problem with stick owners and since it is repaired with the trans out you then need to replace the clutch and RMS. Repair cost at a Indy is $3500-$5000. My suggestions is to take it to a reputable shop and have a PPI done, then you know what you are getting into.
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
