08-03-2010, 12:26 PM
#1
2001 RUF 3800S
RSS under pulley: can I reuse the crank pulley bolt?
I've been postponing this install due to lazyness. Now it's time. I called rss to see If I could reuse my crank pulley bolt and I didn't really get a confident answer but he said for my year yes I can reuse it. Just wanted to know if anyone has reused it before without issues?
IG: RUF3800S
08-03-2010, 12:30 PM
#2
There was a writeup on here very recently covering this.
IIRC, they are not reusable. The bolt stretches when torqued to spec, similar to many head bolts.
98 Arena Red 986
08-03-2010, 01:08 PM
#3
Carnut
How about the belt, then? I guess that has to be changed as well, right?
08-03-2010, 01:53 PM
#4
I have the RSS underpulley, I used the exact same bolt, I have driven the car in a very spirited fashion without any problem, as for the belt, it's a different size, replace the bearings in the rollers too, they are cheap at napa.
08-03-2010, 03:30 PM
#5
bolt replace
I reused my original bolt, no problems so far... that bolt looks like it belongs in a tank, how does it stretch?
01 boxster black/tan- FVD exhaust and ECU tweak, K & N air filter,
de snorked, underpulley, carbon fiber rear wing, H & R lowering springs, lemans rims by victor equipment
08-03-2010, 09:47 PM
#6
2001 RUF 3800S
I called Porsche and the part is like only 4 dollars so ill just switch it just incase. But I thought with the RSS UP you can reuse the same belt?
IG: RUF3800S
08-04-2010, 03:08 AM
#7
[QUOTE=lbrown2009]I reused my original bolt, no problems so far... that bolt looks like it belongs in a tank, how does it stretch?[/QUO
Eggactly, I would only add mine was pristine, zero corrosion or thread corruption.
If anyone wants the roller bearing numbers or the gates belt number message me, I have both in my car log.
08-14-2010, 11:29 AM
#8
2001 RUF 3800S
anyone reuse the same belt? I wasnt told that you need a belt.
IG: RUF3800S
08-14-2010, 12:24 PM
#9
I have the 4" pulley, and replaced the belt with a shorter one, although I believe on your RSS pulley (which is slightly larger), that many have used the stock belt, and the belt tensioner should take care of the slack just fine.
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
08-14-2010, 12:32 PM
#10
In a word, NO wont work. Gates belt for use with RSS pulley from my work notes
belt is 060827
08-14-2010, 01:47 PM
#11
In past I've read articles, wherein boxster and cayman owners claimed to have used the original belt. How they were able to accomplish that is beyond my understanding. When I installed my new under drive pulley, albeit BBI's product, I discovered that the oem belt was clearly too long .
08-14-2010, 05:34 PM
#12
2001 RUF 3800S
belt is 060827
Where can I get the belt and bearing? I googled the belt part number and found a site but it says its for mercury cougars...
IG: RUF3800S
08-14-2010, 07:38 PM
#13
You can get the bearings and the belts right at NAPA, trust me, I made extra round trips due to the same information, do what makes you happy or take my advise and get:
skf bearings 6203-2rsj (same for tensioner & roller, best quality available at napa) and the gates belt number I gave you. You will need a bearing punch or similar drift to drive out the old bearings.
